TR2/3/3A Motor oil for Summertime
karls59tr
Bronze
I am running 20W50 motor oil in my TR3 Is that what most of you use for Summer driving?
ALSO for summer coolant in the rad........anyone using "Water Wetter" in their coolant? I've heard 50% antifreeze/35% distilled water/15% Water Wetter
TuffTR250
I did not have good luck with water wetter. It turned to brown stings and small balls of brown gooey stuff after one drive, even though the antifreeze with it was new. I quickly took it out and put in 20% antifreeze and distilled water. Have had good luck with that. But I keep my TR3 in a warm garage and don't drive it very often when it's very cold outside, which isn't often in North Carolina. But the 20% antifreeze cools better in the summer than 50%.
Bob
K
karls59tr
Bronze
That's odd about the water wetter. I have used it and that didn't happen. Must have been some kind of chemical reaction with something in the antifreeze. Interesting about the 20% rather than the 50%. I went for a drive last week (cooler weather) with a fairly rich antifreeze mixture and when I hit 80mph the temp gauge was up to 200F? Last summer on really hot days with the water wetter the temp never went above 180F?
J TR4/4A Oil leak from rear of motor. Triumph 28
gbtr6 TR6 TR6 Oil Level, New Motor and Leak Triumph 16
H Preferred Motor Oil for 948cc engine? Spridgets 6
V TR2/3/3A Motor Oil Triumph 8
hondo402000 new motor oil Triumph 7
prb51 1st oil change on rebuilt motor Triumph 4
W Classic car motor oil Triumph 16
D Zinc/ZDP in motor oil, the last word. Restoration & Tools 9
Dadandson New Motor Start up with Xtremely High oil pressure Spridgets 5
Dudly Motor Oil Triumph 30
A need advice on motor oil Triumph 9
T Oil pressure when spinning motor on w/ battery Triumph 12
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
B Motor oil Triumph 13
Z TR6 Best break in oil for rebuilt TR6 motor? Triumph 35
R motor oil [changes] Austin Healey 10
77_MG_Midget Triumph 1500 Motor Oil pressure question Triumph 8
1 motor oil Spridgets 23
A motor oil Jaguar 3
G TR5/TR250 Oil leak at front of TR250 motor Triumph 4
J motor oil in cooling system-100/4 Austin Healey 4
MGTF1250Dave Motor Oil Restoration & Tools 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
B Windscreen Motor Repair Restoration & Tools 6
HealeyPassion Pop Quiz: Displacement of 2912cc motor bored 30 thousands (0.030) over Austin Healey 3
W General Tech 2500S starter motor and fuse box questions Triumph 3
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
R TR2/3/3A TR3 Wiper motor Triumph 10
SNClocks Upgraded Motor Mounts Spridgets 4
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
M Engine Stand for 3000 Motor Austin Healey 7
E MGB MGB heater motor problem MG 3
edkap2002 TR6 starter motor advice Triumph 12
T Motor Jaguar 4.2 Jaguar 14
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Motor knocking at start up? Triumph 11
T TR2/3/3A wiper motor short Triumph 2
Darwin Spitfire Motor mounting help Triumph 1
3798j Off Topic My motor...it whistles... Triumph 2
60TR3A TR2/3/3A How Authoritative is the British Motor Industry Heritage Trust? Triumph 6
B TR4/4A Rubber wiper motor mounts Triumph 4
R Rewind electric motor Restoration & Tools 3
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
