Spitfire Has anyone fit a 2500 wiper motor to a spit mk1?
britishcarfreak
I read that the spitfire mk1 had a single speed wiper motor and that it could have a twin speed from later models.
Has anyone managed to fit a 2500 saloon wiper motor to a mk1 spitfire? I've got one downstairs and thought it might be a cheap upgrade.
I was wondering if all triumph wiper motors turned throught the same angle and back or whether some of them had a greater sweep.
piman
Hello Glen,
I would guess that the MK 1 Spitfire and the MK 1 Triumph 2000 used a similar motor. I fitted a MK 2 motor to my MK 1 2000. I had to use the MK 2 rack gland as it is a different shape to the MK 1.
Also the MK 2 motor connects via a moulded plug so you will really need that bit of a MK 2 loom and also the MK 2 wiper switch.
good luck,
Alec
[ 01-07-2004: Message edited by: piman ]</p>
B
britishcarfreak
Yep - good note about the plug wiring.
I'm going to hand build a new wiring loom for the project car and include a few spare wires in there for bits that I may add later on.
The question about the degrees of rotation of the various triumph wiper motors still exists. Anyone....???
piman
Hello Glen,
The 2000 angle of sweep from my manual is 110 degrees, I guess you could measure your Spifire if you don't have the data.
Alec
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
steveg Has anyone used a knock sensor? Austin Healey 0
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
G TR4/4A Anyone know if this car has sold yet? Triumph 0
Sherlock Spokane Race Track, has anyone been there? Racing 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
G Has anyone here had any dealings with ANGLO PARTS.COM ? Austin Healey 4
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
MY66AH Has anyone used this paint?? Spridgets 7
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
H Has anyone changed their electrical distribution? Austin Healey 7
regularman Has anyone here put a bugeye front end on a square Spridgets 2
scoutll Exhaust manifold has cracked-Anyone have a spare? Spridgets 2
60TR3A Has Anyone Undercoated Their Car? Triumph 27
scoutll Has anyone had a hardtop shipped? Spridgets 15
S Has anyone ever seen or heard of this? Austin Healey 9
T Advice, has anyone done this Triumph 2
jlaird Has anyone noticed Spridgets 20
NardisCNC Has anyone used the Oberg Engine Tilt Lift?? Spridgets 15
Cookie Has anyone changed wheel cylinders? Spridgets 20
bgbassplyr Has anyone else Other British Cars 9
L Has anyone ever had to.... Spridgets 12
gubba Has anyone here used this Rack & Pinion? Triumph 8
M Side Curtain Rubber Has anyone tried MacGregor? Spridgets 2
T TR6 Has anyone ever made a new TR6? Triumph 20
angelfj1 Octane Boosters - Has Anyone Mixed their Own? Restoration & Tools 5
S Has anyone seen....... British Motor Corp 1
weewillie has anyone Restoration & Tools 12
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
regularman Has anyone ever done any wind tunnel tests.. Spridgets 22
G TR6 If anyone has had their TR6 on the dyno to tune Triumph 16
C Has anyone seen........ Triumph 6
healeyboz Has anyone.... Spridgets 5
MGBGT_noob MGB Has anyone ever tried this with an MGB? MG 10
jlaird Has anyone Spridgets 4
H Anyone Own or Has Driven a TVR Sagaris? TVR 11
mgblue79 Has anyone tried E85? Spridgets 16
AweMan Has anyone ever .............. Triumph 10
roofman Has anyone installed an electronic voltage ... Triumph 19
W Home-made tonneau - has anyone tried? Triumph 15
Nunyas has anyone else seen this? MG 14
J Has anyone converted to TBI? Triumph 11
neilh Has anyone successfully patched a leaking tank? Spridgets 15
1 Has anyone ever heard this tip? "Weeping" head MG 11
