Ok:
YankeeTR I just went out and looked at mine again, Now I distinctly remember.
You will have to remove the bracket from the bulkhead.
There are six bolts that hole the M.C. bracket to the bulkhead.
You may want to remove the clutch/Brake pedal assembly for easy access. {I did}
The two forward most bolts {the ones closest to the steering wheel have weld nuts on the bracket so you will not need a wrench to hold the nuts} the four bolts {under the pushrods} have nuts {not weld nuts} use a box end wreanch on the bracket side, socket and wratchet from underneath.
As I remember I think I just vice gripped the four with nuts.
you may need to get an assistant to hold the nuts/bolts one side or the other.
Sorry for the misleading info the first time around, it had been a long time sence I did this removal.
