Fred,
It's pretty simple, just take note of how they are located and mark the disc with a marking pen for reference. Make sure the throttle stop screws are backed out all the way. Unscrew the 2 screws that hold the disc to the shaft and pull the disc out, pull the shaft out the side and unscrew the linkage, replace the worn shaft with a new one, reinsert the disc and rotate the shaft until the disc is centered. You may have to wiggle it a little, but it will line up properly. Put the 2 screws back in,but don't tighten them all the way. Double check that the disc is centered and I look for light around the edges of the disc to help me. Once centered tighten the screws that hold it to the shaft. Doing one at a time gives you a reference.
Good luck, Rut
