What do these symptoms sound like to you?
tdskip
Hi guys - the '66 4a is fighting me. Here are the details;
1) Mixture on carb seems right at idle based in piston lift test
2) 25D with points. Advance capped at distributor and carb (yes - will fix but just want to run her around parking lot)
3) Fuel delivery looks OK - filter stays 3/4 at all times
4) The carb diaphrams were OK when I checked them and seated properly
5) I believe I set the float levels correctly
6) New battery cable with good ground
6a) 12.8 v at battery running
Symptoms
7) Will start right up from cold with choke
8) Idles great for as long as I want
9) When trying to get around said parking lot she be OK at tip in then stumble and cut out.
10) If you put the clutch and give her a lot of throttle sometimes she'll recover but usually will die.
11) Sometimes she'll not start again unless I pull the ground terminal off the battery and then push it back on
This cars wiring was hacked prior to mmy getting her.
Any ideas?
mrv8q
Hmmm, can you rev it OK in neutral? Choke linkage return OK? I'm wondering if it isn't running rich; have you checked the plugs? Have fun, Tom!
3798j
Bronze
Here's my guess - timing is too retarded - I'd try advancing the timing followed by a run around that parking lot. If no improvement, 2nd guess - too lean - I'd run the jets up till they hit the piston, then back off at least 3 1/2 turns and test drive to check for any improvement - you can lean her down and balance later. But... got a feeling you've already tried both.
T
tdskip
Hi Kevin - hope you are doing well.
She'll rev fine in neutral.
Choke appears OK.
I haven't pulled the plugs, will do that.
glemon
So it will rev, but won't pull a load? that tells us something, not sure what, as noted play with the timing, which if way off will kill power, also anything dragging in the driveline, brakes tranny, etc.?
Does it take a long time or little bit to warm up so that it will take throttle in neutral without missing or hesitating, if it is OK from the start right away may be too rich, if it stumbles a lot until warm may be too lean. I have never been a fan of the piston lift test, I get pretty much the same results within a very broad range of adjustment.
71MKIV
change the condensor.
trrdster2000
Skip, I hope the gas is new, this corn gas brings water into play very quickly. Might want to put some we make in the mountains of NC in the tank and if that doesn't help , put some in yours.
Wayne
Platinum
Check th' carb diaphragms again... hold 'em up to sunlight and stretch 'em.
:wink:
Tr4dude
if everything else is good, look under the hood in the dark and see if you have fireworks around the plug wires or spark plugs, had this happen a couple times before with other cars.
hondo402000
you speak of timing. it has been noted that on old dampers the rubber breaks loose and the outer ring with the timing marks will move in relation to the inner hub making accurate timing adjustment impossible. you would need to bring no 1 piston to TDC and check where your timing marks are. thats the only way I know to make sure your timing marks are correct.
Hondo
TR3driver
Great Pumpkin - R.I.P
The fuel filter is a very poor indicator of fuel delivery. If you can't check actual pressure when it dies, then try checking delivery volume by directing a fuel line into a jar or something while you crank the engine (or have it idling).
Does the battery voltage not rise at fast idle? If not, your charging system isn't working.
Based on recent experience, I'd try a "known good" coil & condensor. I had somewhat similar problems with the TR3 that proved to be a failed coil (a Lucas Sports coil that was less than 2 years old).
T
tdskip
Wayne
Wait - to drink or use as fuel?
(tank has been drained - so don't think that is it. No separation that I can see)
mrv8q
Any solution, Tom?
T
tdskip
mrv8q said:
Any solution, Tom?
Hi Kevin, thanks for checking in.
She is out at the hanger so I won't get to pick at her until the weekend.
I've been working on the 911 instead as it is in the garage. The darn thing was built by Martians if you are used to TRs.
Platinum
tdskip said:
I've been working on the 911 instead as it is in the garage. The darn thing was built my Martians if you are used to TRs.
:lol:
Chain tensioners! :laugh:
T
tdskip
Yeah, and it has some sort of computer in it or something. Weird.
And I still haven't found the radiator.
(Doc, she a '74 with a late 3.2 Carrera engine in her. Fast, fast, fast)
Platinum
w00t-w00t!!! :laugh:
Keep lookin'. They hid it in there <span style="font-style: italic"><span style="font-weight: bold">someplace</span></span>! :jester:
A pal has an earlier shell (1969), replaced the 2.4 with a Carrera 3.6... Track car, somewhere around 1600 pounds. BRUTAL!
DanB
Sounds like the problem I always had with mine. Tried all the stuff listed plus re-routing fuel lines away from heat, electric fuel pump...
I finally fixed it. EFI.
K TR2/3/3A What are the running symptoms........ Triumph 21
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
G Brake Booster Failure Symptoms Austin Healey 3
Rut MGB Running out of gas symptoms MG 21
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
charleyf TR4/4A Symptoms with bad condenser Triumph 14
NutmegCT Generator symptoms Other Cars 15
YYCDave Un-Balanced Carb Symptoms Triumph 5
TulsaFred What are the symptoms of worn throttle shafts? Spridgets 9
I end of long drive symptoms Austin Healey 23
T Reversing w/. OD engaged - symptoms? Triumph 14
S TR6 TR6 Blown Head Gasket Symptoms Triumph 14
1 T-Series More clutch failure symptoms MG 25
G Strange XJ6 symptoms Jaguar 5
LastDeadLast Interesting symptoms Triumph 37
JPSmit Beetle Signal Symptoms Other Cars 6
G What are the symptoms of a chain tensioner going.. Triumph 2
M Symptoms in need of a diagnosis Spridgets 18
Woodie failing condensor symptoms Spridgets 28
dklawson Symptoms of Stuck Valve ??? Spridgets 19
Nunyas What are the symptoms of... MG 7
Patton Rocker Arm Clearances too Large Symptoms Austin Healey 5
Patrick67BJ8 Insulation and Sound Deadening Austin Healey 0
M TR6 Clicking sound when accelerating Triumph 11
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
nichola TR6 Stock exhaust sound... short video Triumph 4
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
J TR6 Does this sound ok to you? Triumph 5
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
DerekJ Sound proofing recommendations Austin Healey 8
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
maxwedge5281 no sound when breaking the christmas bulbs??? Austin Healey 16
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
C A better sound for a Miata? Other Cars 0
GTP1960 TR2/3/3A Loud scraping sound in clutch area Triumph 12
T sound for a bug-eye??? Spridgets 2
N MGB-GT Carpet, sound proofing, and painted bumpers, Oh My! MG 15
W Sound 1966 Sprite rolling chassis Spridgets 0
HealeyRick Alternative Sound Systems Restoration & Tools 2
AN5Sprite F1 Sound Comparison 2013 vs 2014 Racing 2
Boggsy64 MGB Sound deadener MG 4
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
M Replacement Sub-Woofer for X308 99 XJ8 with Premium Sound System Jaguar 1
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
JPSmit What is that strange grinding sound in the distance? Spridgets 3
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
