Generator symptoms
NutmegCT
My 1958 Rambler American is running great!
But ... when I start the engine, the red generator (No Charge) light stays on for a couple of minutes. Regardless of engine speed.
After driving a few minutes, light goes off. (Light comes back on at engine idle, which is normal.)
After market voltage meter shows 16 - 17 volts all the time; never settles back to the 14 it used to show a couple months ago when driving. Have to admit, I've driven the Rambler more in the last two months than in the last two years.
Generator belt is two years old, and isn't too loose or too tight.
Generator is an original Delco/Remy 1100304; regulator is a relatively new Delco/Remy 1119122.
I've ordered new generator brushes, springs, etc. just in case.
How can I test if the problem is (1) generator, or (2) regulator?
Thanks.
Tom M.
Gliderman8
That's a good looking car Tom!
Mickey Richaud
Maybe these will help with the regulator test:
NutmegCT
NutmegCT
Thanks gents. Onward into testing mode!
Here's a link to further photos:
https://s224.photobucket.com/user/freemangarden/library/1958 Rambler American?sort=6&page=1
Note the bolt-on "log manifold" at the engine. Just an extension of the exhaust pipe, with three holes in the pipe, matching three in the head. The keyword on this car was "simple" - and the sunvisors and oil filter were options!
I'm trying to get it back to "just off the showroom floor" condition. Well ... sorta ...
NutmegCT
NutmegCT
The mystery deepens.
Generator output (tested using my multimeter) is nothing for about ten minutes. Then suddenly zips to 16 volts and stays there. Output is zero when not turning, still zero when at fast idle, still zero at warm (slow) idle. Then rev the engine a bit and output bounces up to 16 and stays there.
Your thoughts?
Mickey Richaud
LarryK
Brushes. Then reset voltage reguator
NutmegCT
NutmegCT
Thanks Larry. I've ordered new brushes. My gut feeling is that the brushes finally gave up the ghost as I've been driving it more in the last two months than in the last twenty years.
When you say "reset" the regulator, do you mean re-polarize the generator by quickly jumping the regulator's A (battery) and F (field) terminals?
Tom M.
LarryK
Yes. Friend has an old Jag and he rebulit the generator and was advised to repolarize both generator and regulator. I used to do this years ago, but getting old enough I had to look it up to do it.
NutmegCT
NutmegCT
Saturday update - victory!
I took the generator to a local old-school shop. The guy put it on his test gizmo, spun it up, meters all read zero. Looked at me and said "He's dead, Jim".
Said the problem was a burned out armature (whatever that means).
So he took it all apart, cleaned and repaired, put in my new bearing, springs, brushes - and ran the test again. Success.
I put it back in the Rambler, repolarized, girded my loins, started the engine and ... the little red light went off when the engine was running! Output at 3000 rpm about 14 volts.
I am a happy camper.
Mickey Richaud
And all this time you've said your name is Tom...
Glad you got it sorted!
He's a car nut, not a doctor. Lol. Good job on the diagnostics.
Mickey Richaud
AH! Got it - completely blew right past me! Guess it's been too long since I've seen Jim and Dr. McCoy.
NutmegCT
NutmegCT
We now return to our regularly scheduled program.
Take a look at the attached Delco-Remy regulator sheet. On page four, "Temperature Compensation".
The output voltage changes relating to the ambient temperature. Cold engine bay - higher voltage output. Warmer - lower output.
Never knew that!
Edit: Can't attach the pdf file. BCF message "Your file of 1.76 MB bytes exceeds the forum's limit of 976.6 KB for this filetype." Didn't know the limit was so low.
Here's a link:
https://www.stinsonclub.org/PublicTech/YahooGroup/Delco-Remy%201R-116%20(regulator).pdf
MGTF1250Dave T-Series Lucas Generator MG 1
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
T Spitfire MK2 Generator Triumph 3
W Generator and Starter Long Bolts Spridgets 0
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
B Generator Parts Austin Healey 6
P BN4 Generator Woes Austin Healey 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
TR3MT TR2/3/3A Generator Output Triumph 18
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
AUSMHLY Generator to Alternator Swap Austin Healey 20
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
J Wanted WTB TR 3-4 Generator pedestal Triumph Classifieds 3
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
O Generator Question Austin Healey 2
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K What to do for coil bracket on upgraded generator? Austin Healey 8
R TR2/3/3A generator to alternator Triumph 5
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
T New Generator Mystery Austin Healey 5
I Bugeye generator/alternator conversion question Spridgets 7
NutmegCT Ozone generator - cigarette smoke smell in car? Restoration & Tools 11
S TR2/3/3A no leaks, but the generator is not charging Triumph 45
R TR2/3/3A TR-2,3 Generator Pic showing all attachments Triumph 5
doc50 Mash Metropolitan Generator testing Other British Cars 1
S TR2/3/3A generator red light deal Triumph 6
J advice on a 3 brush generator please C45N-3 Other British Cars 0
5 Tach Drive Generator for a Bugeye Spridgets 2
M Jaguar XK Special Equipment Generator Jaguar 1
T C42 BJ8 generator long screw needed Austin Healey 2
Magyar Generator going on the fritz Spridgets 3
Rhodyspit75 Generator pulley diameter Spridgets 2
A Wanted WTB Generator pulley & fan Austin Healey Classifieds 2
Rut Bugeye generator color Spridgets 22
CJD TR2/3/3A Generator and other Odds Triumph 6
G TR4/4A New Generator vs Alternator vs BPNW Alternator/Generator Triumph 13
R TR6 Generator to alternator conversion Triumph 6
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
K TR4/4A Generator bench testing..... Triumph 6
G Generator - Key Replacement Austin Healey 6
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
