Worn clutch bits, etc
aeronca65t
I wrote about the worn bushing in my clutch arm a few days ago but I discovered more issues so I'm starting a new thread:
After we finished running at the newly-reopened Thompson (Conn) race event I noticed the clutch pedal needed to go to the floor before I got full disengagement of the clutch.
But the week after Thompson, we had rented a house at the beach. We had a dozen family members joining us that week (kids, grandkids, siblings, etc.) so the car only got a cursory safety inspection plus oil change. We had a great time at the beach!
When we arrived at Pittsburgh International Race Complex (Pitt-Race) for the first weekend of the PVGP, the clutch pedal seemed a little worse. There was no air in the system and I hypothesized that the clutch release arm is bent or the throw-out bearing is worn. The system is self-adjusting so there's no issue there.
We make it through the Pitt-Race weekend with some grinding but we do OK. I actually got a podium in one race (third) plus the Worker's Choice in another session (note to non-racers: Worker's Choice is like winning a prize for Miss Congeniality). Anyway, we win a case of beer for each of those so we are well stocked.
But I'm worried about the clutch. It's now at the point that I can barely get it in gear without rolling the car and even shifting into the second, third and forth are rough.
The second weekend of the PVGP puts us in Shenley Park which has a very tight paddock area. I worry about the clutch in these tight quarters and tell my friends I hope I have "one Shenley's worth of clutch pedal left".
There were a few very ugly shifts but we made it through the weekend and had a great time. I ordered parts from Moss while in Pittsburgh in anticipation of pulling things apart when home.
I pulled the motor last Wednesday and found the problem. This is one I don't recall seeing before; a very worn bushing in the clutch release arm. I had a good, used spare arm so in it went. But I wondered what had caused it? Then I realized my throw-out bearing was the "modern" roller type. These cars normally come with a carbon throw-out bearing but I had forgotten that I'd fitted this roller type unit a couple of years ago. Actually, I didn't specifically buy the roller bearing; it came in a used trans trans that I'd picked up. When looking at the roller throw-out bearing vs. the carbon throw-out bearing, there is an obvious difference in thickness. This, in turn, probably changes the fulcrum point of the load. I wonder if this caused increased load on the release arm bushing? It's hard to say, but since I had ordered a normal carbon bearing, I installed it and all the arm geometry should be back to normal. If I were to use another roller bearing in the future, it would have to be with a modified arm to keep the geometry correct. Or the roller bearing thickness would have to be thinner.
One other point; with the incorrect geometry caused by added thickness, the throw-out bearing was not "on center" with the pressure plate. The amount of error is probably minor but still......not good.
Since I was pulling it apart anyway, I decided to fit a new clutch disk. The old one was "biting" fine but a new disk is cheap and it seemed like a useful idea.
Actually the old disk was still decent but the pressure plate was about to break apart! It was riddled with radial heat-stress cracks. I'm glad I decided to replace the disk as it gave me a chance to see this. That pressure plate had been fine about 18 months ago when I installed it.
The funny thing is, I consider myself pretty "easy" on clutches. I never do any drag race starts and my current engine is very mild so it doesn't require a lot of slipping to get launched.
I put in a good, used pressure plate but I will be keeping an eye on it from now on. It's all back together and seems to be working fine. Next weekend I'll be at New Hampshire Motor Speedway so we will see it it's really fixed.
Worn clutch release arm bushing:
Thickness difference; roller throw-out bearing vs. carbon throw-out bearing:
Radial heat stress cracks in pressure plate:
Jim_Gruber
Nial, the old ounce of prevention adage applies here. Part of prep work is reliability and being able to finish the race. Good luck next weekend.
On the Rivergate 5 speed kiit (that uses the datsun throwout bearing) they remove the contact pad so that the bearing presses on the clutch fingers. It seems to work. You might check to see if that is an option with your bearing/geometry.
Billm
Nial
Is the worn out bushing floating free in there? The worn out part is on the opposite side from the force it sees in use.
BillM
aeronca65t
aeronca65t
Nial
BillM
Hmmm?
Not quite sure about that...
The roller throw-out bearing can be seen in the right upper side of the first picture. The wear on the pivot point seems in the correct place to me.
JT--Having the roller press directly on the diaphragm springs might be a solution!
Billm
....but that wear would have given it the extra motion that you were seeing and causing most of your problem (as you already knew)
Bill
G
I would have to guess the heat cracks are due to heat warping and that due to the malfunctioning clutch lever. Notice it's really only in one area....OR..
Knowing you and the statement, "That pressure plate had been fine about 18 months ago when I installed it" would tell me it's most likely a used plate and upon seeing the rust pits and rivet hole rust rings I would have to guess that PP was installed by you used from outta the spare bits pile. That being said, Lord only knows where it came from, who it was originally installed by and if it was installed correctly.... It mighta already been warped when you got a'holt of it.
I could be full of carp too....which....as we all know.... is the most likely scenario :grin:
nomad
Nial, I've read articles on the roller bearing swap for the carbon before. Some say it's not the way to go. Just a look at the two system's can't help but make one ask question's. In the normal roller TO bearing application the bearing normally slides on the tube that surrounds the motion shaft and it is often retracted by a spring on the throw out arm. The carbon bearing moves through an arc when in use and run's constantly against the pressure plate pad. I think that if I fitted the roller TO bearing I would fit a spring to retract it so that it wasn't contacting the pressure plate all the time.
Kurt.
Billm
Kurt
The only possible problem with that is that the bearing would be pulled so far away that it may not make contact when the peddle is pushed. The Mini had a spring but it also had an adjustable stop to prevent over retraction.
BillM
nomad
I agree Bill, and I had thought that one would have to figure out a stop or have the slave be fully retracted and use that as a stop.
Kurt.
davester Is this normal for a worn out clutch? Spridgets 2
V GT6 Shifter Worn? Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
2 Wanted SU-h6 Carb. BODY ONLY needed, badly worn. for TR3A Triumph Classifieds 5
H TR4/4A Worn Fulcrum pins Triumph 5
L 100 timing chain worn? Austin Healey 7
5 Worn steering box Austin Healey 4
Rob Glasgow Worn Hub Extension Studs Austin Healey 2
TulsaFred What are the symptoms of worn throttle shafts? Spridgets 9
M Worn out throw out bearing Spridgets 4
mgnewbie worn/old front suspension bushes MG 3
PatGalvin TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn? Triumph 6
M Front hub worn out Spridgets 6
livinginthepast Anyone have a worn out old 948 engine for sale? Spridgets 9
TR6oldtimer TR6 Worn Thrust Bearings TR6 Triumph 26
M Tire Worn Uneven Spridgets 4
B worn Webber carb MG 7
Tinkerman Worn Shifter Forks Triumph 6
jcatnite Worn gears Spridgets 15
Thor Do you have to ream swivel axle if not worn? Spridgets 6
Mark Jones Differential nut removal & worn thurst washer Triumph 1
Bob_Carroll TR6 Worn #1 Exh Cam Lobe - TR6 Triumph 9
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
