We have Vroom, Vroom and an oil leak from the Oil Filter!
apbos
After 35 years we finally have startup. Thanks to my uncle and all of you we were able to get her running today. Just a reminder of what she looked like when Doug M told me about her......
Carbs need some adjusting and we need to do more of the wiring and fix the oil leak from the spin on oil filter!
The car came with a spin on oil filter with poor rubber O-rings. In my haste I for got to change them and now it is leaking. Any ideas about what size O-rings they are and where I can get them?
Again thanks. I will update the $500 Bugeye post later when I have a video. Tony would be proud to have a part of this and all of you should be proud of what you have helped me accomplish.
Paul
nomad
Looks nice Paul and you should be able to get an O-ring to fit at any hardware store or farm supply store.
Kurt.
SaxMan
That's always a neat feeling bringing something back to life that someone else had written off. Congrats!
drooartz
Quite the transformation! Makes me feel like I'm cheating with my project. :grin:
Nice work, much to be proud of there.
Rut
Paul,
WOW, what a transformation! You have done some beautiful work, more pictures!
Rut
dklawson
+1 to Nomad's comments on getting the o-rings from local sources. Though they may not be out front, I suspect most parts houses will have a selection behind the counter.
Common inch size o-rings follow the AS568A industry standard where the AS568A prefix be followed by a 3 digit suffix. Measure the o-ring gland size as close as possible for ID, OD, and depth, then visit the McMaster-Carr web site (www.mcmaster.com). Type "o-ring" into the search field and look for the nearest size o-ring that fits the gland then write down the 3-digit suffix number and take it with you to the parts store and they should be able to supply what you need. (i.e. If the o-ring gland looks to be about 3/4" ID by 1" OD and measures about 0.1" deep, you would need an AS568A-210 o-ring. You can use normal Buna-N (Nitrile) or Viton with gas and oil (never use EPDM with gas or oil, never use silicone with gas). The typical/common hardness for common o-rings is 70 durometer for Buna, 75 durometer for Viton.
Billm
I was thinking about this today-
doesn't the o-ring come on the oil filter and not on the adapter?
If you just buy a new filter it should have the o-ring.
BillM
apbos
apbos
Thanks for the complements guys! Bill the spin-on adapter has 2 o-rings. I will take the entire unit off and take it with me to the local farm store and see what they have. No one seems to list what size they are. Moss UK still sells the kit. Might give Moss US a call to see if they have any idea. The kit Moss sells now appears to have changed.
Paul
nomad
Agree with Bill...if the oil leak is around the top of the filter then you would need to replace the screw on filter. If memory serves there is also a O-ring between the filter block and the engine block.
Kurt.
Jim_Gruber SUCCESS- VROOM, VROOM has been heard in Beavercreek, OH this evening Spridgets 31
R have VROOM again on engine rebuild, breakin check? Spridgets 8
Jim_Gruber Vroom, Vroom-Oh what a difference in handling Spridgets 11
Jim_Gruber Vroom, Vroom sounds from Bugsy Spridgets 2
L Turbocharged, efi MG MIDGET. VROOM, whoosh, psssss Spridgets 19
drooartz VROOM VROOM!!! Spridgets 28
drooartz This coming weekend will be my first Vroom attempt Spridgets 8
abarth69 Vroom Vroom round and round Other Cars 15
JPSmit Vroom Vroom Spridgets 18
JPSmit Vroom Vroom er sort of Spridgets 11
L Another partial Vroom! [Megasquirt] Spridgets 6
L Intermediate VROOM minus Distributor-> EDIS!!! Spridgets 11
Jim_Gruber Vroom Vroom Bugsy is making good sounds once again Spridgets 6
Jim_Gruber Vroom, Vroom sort of! Spridgets 4
RickB Here it is - my Sprite Vroom post... Spridgets 13
abarth69 It has life Vroom,Vroom Spridgets 2
Bruce_B Ain't got no Vroom, Vroom, Vroom Spridgets 12
Baz VROOM VROOM!!! Spridgets 16
Jim_Gruber Vroom, vroom sounds heard once again. Spridgets 3
Monark192 Vroom Vroom - another one lives! MG 2
J carb piston keeps dropping... no vroom vroom Triumph 19
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
