Upper link triangulation
Morris
Another one of my crazy ideas...
Could the lever arm and shaft from an MGB front shock be fitted to the lever body of a Spridget front shock?
Looking at the pictures... the dimensions seem very similar. But pictures are a bad way to judge that kind of thing.
Does anyone have an MGB front shock and Spridget front shock he can lay side by side?
S TR4/4A Reversing upper fulcrum link Triumph 3
Morris OOS Upper Link Spridgets 6
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Rut MGB 62-67 upper MGB steering shaft MG 3
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
P MG TD Bonnet Upper Sections MG Classifieds 0
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
R TR2/3/3A Upper Wishbone Bushings Triumph 12
L TR2/3/3A Upper steering column bushing Triumph 8
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
D 62 tri-carb upper fulcrum pins Austin Healey 4
J TR4/4A Upper steering flex coupler Triumph 4
R TR6 Body Parts Source, Upper Midwest Triumph 6
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
J TR4/4A confirm upper wishbone arms Triumph 11
KVH General TR Upper Control Arm Reversed? Triumph 5
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
vickxxx TR2/3/3A Upper cylinder oiler Triumph 8
B TR2/3/3A Upper Control Arm - which overlaps which? Triumph 2
GTP1960 TR2/3/3A Tire condition, upper side wall splits...dangerous? Triumph 12
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
T TR4/4A Upper steering column Triumph 3
G TR2/3/3A Steering Box Upper Bearing Race Triumph 1
C Sway bar upper installation help please Austin Healey 3
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
B TR2/3/3A Adjustable Upper Fulcrum for TR3 Triumph 9
V Upper Ball Joints Triumph 16
B Upper radiator stay rods black or body color? Triumph 11
bcbennett '74 upper radiator hose Triumph 5
T TR2/3/3A TR3A upper windshield seal Triumph 12
I TR6 TR6 upper A post seals Triumph 0
T TR2/3/3A TR3 upper A arm bushings Triumph 6
D MK2 upper radiator hose question Jaguar 3
K loctie upper rod bushings Triumph 4
memphis Door Panel - Upper Piece? Austin Healey 8
JPSmit fixer upper Spridgets 5
Steve An Upper-Crust Spot Today Spotted 4
PatGalvin TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn? Triumph 6
Tinkerman TR 3 Upper Column Felt Bush Triumph 7
jerrybny Upper C arm resistance Triumph 4
bigjones Upper Ball Joint Fun and Games Triumph 15
