Tyre question
bloodyank
I'm putting 14" x 6" Superlite wheels on my Morris Minor Traveller, and as it had 13" from a disc brake conversion, and as I don't know squat about tires, I wonder what the range of tire sizes I can get is. I'd like to go as wide as possible, maybe 195?
Thanks,
-Dave
K TR2/3/3A Tyre question, and an Latest Triumph 9
Simon TR4a Tyre [tire] storage question. Restoration & Tools 4
S BN1 Wheel-Tyre Combination Austin Healey 10
Hamish Racing 3 sisters sprint deformed tyre Racing 4
Hamish Racing General Tech Wheel and tyre selection Triumph 11
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
D Scuttle shake and tyre pressures Austin Healey 2
T determining tyre pressures Austin Healey 9
T Trying to find an accurate tyre pressure gauge Spridgets 24
T Finding an accurate tyre pressure gauge? Spridgets 5
T intermittent deflating tyre Austin Healey 6
Z BN1 Tyre Diameter Austin Healey 8
T 100 4 Tyre Pressures Austin Healey 3
W GT6 GT6 MK3 "TYRE" sicker Triumph 3
blackdog Tyre rubbing under hard cornering Austin Healey 12
T Spare Tyre vs 'Inflate & Seal" Austin Healey 10
T Free Dunlop Gold Seal 5.20 13 bias ply tyre Spridgets 5
T Tire [tyre!] pressures Spridgets 1
1 BE spare tire [tyre] is slipping Spridgets 17
Geo Hahn Tyre Balancing Triumph 13
O tyre wear Triumph 3
J Tyre and wheels size Spridgets 9
Chatis Tire's [Tyre's] for a Bugeye Sprite Austin Healey 2
Kira Tyre Help Restoration & Tools 2
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
