Tube vs Tubeless discussion :]
Healey Nut
Yeah But:tainless Steels Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels '
So U really do not know what you have unless U ask.
A magnet can help you decide good or bad>
Not only did I ask but I took a magnet to them once I got them and the spokes are not magnetic meaning they contain minimal or less iron .
I used to work in a brewery as a millwright so 304 stainless was everywhere so I do know the difference between good and cheap stainless .
Keoke
I was talking t Roger Goofed OK
RDKeysor
Bronze
I am running tubes on my 60-spoked chrome wires. I believe they are Daytons. I had two broken spokes on a front wheel when I acquired the car six years ago. Replacing them wasn't too difficult once I had a shop remove the tire. Just put Kuhmo 185s on the car and used new tubes. Which means these wheels came to me with tubes. Back in 1963 I was working as a reporter for the Dayton Daily News and owning a BJ7 with painted wires and several broken spokes. This car had been actively drag-raced--it had cutouts on the exhaust and a switch for the overdrive on the shift knob. Took it to Dayton Wire Wheels--then located in Xenia, as I recall--and the only person on hand, the proprietor, I believe, cut out the old spokes, put in new ones, painted them, and then suggested I purchase the Dayton wheels, which he said were stronger than what came on my car. I soon had a pregnant wife and the Healey found a new owner. I didn't get another until about 60 years later.
AUSMHLY
AUSMHLY
72 spoke wheels are stronger and Daytons use Stainless steel spokes , they guarantee they will not need to be retrued .
also they have a thick bead of what looks like silicone rubber over where the normal rimband would go .
I dont know anyone who uses Daytons that has had issues or broken spokes .
Do Daytons use a different stainless steel spoke then Dunlop?
Tubeless rims supposedly need a different type of bead; anyone got the scoop? My Daytons were tubed to begin with, but I've had them sealed, with varying success, and now I'm running a couple with tubes. Tubeless is better if they seal; I've had a couple tubes go flat due to chafing.
Healey Nut
Right off an email that Iget every day from a supplier
RAC68
Hi All,
It was in the early 1990s that I purchased (4) 72-spoke wires from Dayton. Keep in mind that, back the, I attributed my biggest frustration to un-trued and unbalanced wheels and chose the stronger 72-spokes to address this issue (not recognizing my problem was with unbalanced brake drums).
After reading a number of articles on what to consider when making wires tubeless, I decided to stick with what I was familiar and chose tubes. Today, however, with the changes in Dayton's and tire technology, I would opt for having tubeless even though I have had no issues (including broken spokes) with my wheels.
As I understand, tubes can chafe and, when punctured, tend to loose air quickly. However, with a similar punctured, tubeless tires will loose air slowly and can be repaired with a plug without dismounting. In both cases, Dayton (I don't know about modern Dunlop) has incorporated technologies have a way to maintain proper wheel truing and air pressure
without objectionable maintenance
Although I have no present intention of purchasing new replacements for my presently installed Dayton wires, if I did I would take advantage of the improvements.
Ray(64BJ8P1)
John Turney
I bought my Daytons prior to them coming tubeless straight from the factory. British Wire Wheel (no longer in business) asked if I wanted tubeless. I said yes. They used silicone to seal the spokes at both ends, at the rim to keep air in and at the hub to keep grease in. That was about 20 years ago.
F Tube or Tubeless? Spridgets 2
A TR2/3/3A TR-3 tube or tubeless-Tire Experts? Triumph 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
J TR6 TR6 Cross Tube Differences? Triumph 6
R Capillary tube temp gauge Austin Healey 7
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
K TR4/4A Pushrod tube leaks? Triumph 2
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
D TR2/3/3A Vacuum advance tube Triumph 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
T Tube shock conversion BJ8 Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
TomMull TR2/3/3A Brake tube Triumph 18
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
