Tube or Tubeless?
Falkon
That is the question.
If you want to skip my thinking just read the last line.
So I have been looking at getting my tires done soon. But every time i come to make my final decision two things always make me take a step back and think. Here's my problem.
I love the look of the wire wheels i have but people are telling me that the tubes that you have to put into the tires are unreliable and not safe. On the other hand other classic car owners say that they are just fine.
Now if this is true i would go to the regular tires but the problem there is that its way to expensive to get just the rims, and i don't know how to take off the knock off bolt and change it to the 4 nuts.
I would like to stick with my wire wheels and just put the tubes in them but i don't want to be driving down the road and have one blow and crash my car. So the question still remains. Tube or Tubeless? And if tubes, are they really that unreliable.
Tullamore
Most of my cars have wire wheels and I have had many flat tires over the years. I don't understand how they could be more dangerous, the sidewall of the tire will support the car just the same if you have a flat/blowout.
The trick to wire wheels is to make sure all of your spokes are tight and to use a rim band or the special adhesive that protects the tube from being punctured by the end of a spoke.
I would stay with your great looking wires and if taken car of they should keep on working without problem.
Platinum
There are tubes made specifically for radial tires, the bands for keeping the spoke ends from abrading the tubes are available. Talk to some REAL tire experts. Keep the wires.
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
A TR2/3/3A TR-3 tube or tubeless-Tire Experts? Triumph 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
J TR6 TR6 Cross Tube Differences? Triumph 6
R Capillary tube temp gauge Austin Healey 7
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
K TR4/4A Pushrod tube leaks? Triumph 2
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
D TR2/3/3A Vacuum advance tube Triumph 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
T Tube shock conversion BJ8 Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
TomMull TR2/3/3A Brake tube Triumph 18
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
