TR2/3/3A TR-3 tube or tubeless-Tire Experts?
Arrow
Any tire experts out there? I am having Dayton make wider wire wheels for one of my three TR-3. Tire technology has certainly changed. I have put Beta fenders on the rear and can run either 15 or 16 wheels tubeless BUT the front wheels can only be 5 inches wide and Dayton can only make 15 inch as tubeless. The 16 inch must have tubes. Any tire experts as to running radials with tubes. Todays tire technology leans to lower profile tires. Car has Mustang II front end rack with coil overs. Rear is 3.5 posi with four link. Coil overs all around. Big drilled and slotted brakes.
Geo Hahn
I'm certainly no tire expert and your mods put you way past my techncial level -- but I'll say that I have used tubes in radials for 38 years with no problem I have ever attributed to that combination.
TR3driver
Great Pumpkin - R.I.P
I'm no expert either, but IMO you will be fine as long as you stay away from the load limit for your tires. Generally that's no problem with a TR3. However, there is a chance the shop will refuse to mount tubeless tires with tubes in them, in which case you'll need to look for a different shop.
The problem is that the tubes cause more heat to build up in the tires, so the tires need to be derated for use with tubes. But the tire makers don't publish the derating factor (probably because the DOT won't let them).
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
F Tube or Tubeless? Spridgets 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
J TR6 TR6 Cross Tube Differences? Triumph 6
R Capillary tube temp gauge Austin Healey 7
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
K TR4/4A Pushrod tube leaks? Triumph 2
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
D TR2/3/3A Vacuum advance tube Triumph 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
T Tube shock conversion BJ8 Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
TomMull TR2/3/3A Brake tube Triumph 18
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
K TR2/3/3A Another question about pulling the wiring thru the stator tube... Triumph 15
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
