trans leaking, any additive to stop it
mudd
have a rebuilt trans with overdrive, thing still leaks, does anybody know of an additive to put in to get these things to stop dripping oil all over the floor?
5
57_BN4
yup
Most Japanese OEM's use it (Kawabond, Yamabond, Hondabond etc) and it is probably the best sealant I have come across.
You also will have to install a seal on the input shaft if there isn't one already and modify the dipstick to have an oring rather than the felt thingy.
My trans is still completely leak free after several hours dyno running- except for a small weep coming down the tailshaft nut thread as I forgot to put thread sealant in there. Got to pull it all apart now anyway to fix the synchro cones.
Sorry, probably not the answer you were after eh.
Andy.
WaltCasten
Yes, I wouldn't add anything to the oil. "Stop Leak" products swell seals and I don't know how that would react with the wet clutch of the OD...not to mention that those products won't really help if it's coming from the input shaft seal, output shaft seal or at all if it's coming from either side of the brake ring in the OD because there is no gasket in there for it to swell.
I had seen and thought about trying this product for my leaky trans/OD which you apply from the outside:
https://www.permatex.com/resource_auto_archive/pr_auto_07252007.htm
There's a cheesy infomercial for a similar product where a guy sprays it on a screen bottom boat and floats around in it but I figured that since this was made by Permatex it might actually work. It says "goes on clear" and would only assume it stays clear or they wouldn't even mention it. The only thing like with anything you'd put on from the outside would be if you could get the area clean enough for it to take.
Just an idea...
Lotuswins
Hi Mudd,
Yes, don't add anything to the oil, saying that, you do know that the trans uses 30 wt oil, not 90 wt gear lube? I say that as I had no idea until I had to remove the trans/OD and replace the piston, rings, and liner due the DPO's use of 90 wt. The clutch was jammed so hard it had to be pryed apart...
Also, and you might look for this, mine had a warped rear housing on the OD due to the wreck it had been in. Apparently the trans locating rod/bushing can warp the case if the shunt is severe enough. The engine/trans has so much movement on the motormounts, it will bend the front frame crossmember too. I was able to chuck the case in a lathe and true up the fit without removing too much material. It went back together fine, and now doesn't leak.
Where is yours leaking from?? I know the drain plug on the OD is famous for leaking, but that should be able to be fixed readily. Otherwise its the seals or the case gaskets or ??
Hope this helps....Jerry Rude
BJ8/Lotus Europa TCS
M
mudd
cant tell really where its coming from, seem like the top somewhere. after driving, it will drip for about a day, then after i clean it up, nothing, so i am assuming that its dripping down from the top someplace, hard to tell without jacking it way up in the air and getting under it.
Flatten a big cardboard box and drive over it after a long drive and let the car sit for a couple hours. Then, find the spots and draw an imaginary vertical line orthogonal to the center of the spot(s). At the end of line will be the approximate location of the leak source.
My bet is you're leaking from a) the hole at the bottom of the bellhousing (common) and/or b) the big brass nut on the bottom of the O/D (also common). Obviously, if the spots are elsewhere then you have gasket or seal issues.
M
mudd
good advice, ill try that, i drove it without the overdrive, didnt see any oil on the ground, so im thinking its coming from the OD someplace
2 repair guys said they use 20/50 oil in the trans, is that correct?
mudd said:
... 2 repair guys said they use 20/50 oil in the trans, is that correct?
I used 20W-50 oil for years with no problems. A few years I decided to try synthetic (Redline MT-90) to see if the O/D would engage a little quicker. It did, but I was totally surprised that shifting seemed smoother as well. Also, when I did finally change the MT-90 it appeared there was less of the finely ground brass 'shake' in suspension.
Others recommend Redline MTL, which is a little thinner. The main downside is cost and the synthetic is almost impossible to contain. I decided to live with some leakage and just top up more often.
Note the 'book' calls for straight 30W 'non-detergent,' although IIRC my BJ8 shop manual allows 20W-50 as well.
Richard Dickinson
I used some stop leak stuff I got at auto parts store in a Ford truck with an auto transmission. Stopped the leaks and the truck ran with no problems for a number of years. Of course the transmission had transmission fluid and not oil in it. The stuff supposedly swells the seals and gaskets.
M
mudd
seems like the trans rear seal is leaking, anybody have a fix for this, other than pulling the interior apart and removing the trans to replace the seal???
sad part is, supposedly the seal is new.
thanks
roscoe
You can replace the rear seal with the transmission in place (at least I did with my BN2). You need a small slide hammer that has an adapter to hold a small sheet metal screw on the end. With the driveshaft removed or at least out of the way you drill a couple of small holes in the sheet metal of the seal (look at your new seal to see what I mean). You thread the screw into one of the holes and give a few taps with the slide hammer; if the seal starts to come out put the screw 180 degrees from the first hole and repeat until the seal pops out. Install the new seal with the sealant of your choice on the OD of the seal (sparingly)and tap it into place with an appropriately sized socket( be careful not to deform the seal when "tapping " it into place). I have welded a nut onto the adjuster of a pair of vice grips and thread my slide hammer on so I have a slide hammer with a vice grip at the end of it. I use the vice grip to grab the screw. Your mileage may vary but it worked for me. You might try gently getting under the lip of the seal with a cotter key puller and pry it out that way. I've done that too but you must be careful not to damage the surface that the seal runs on.
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
T General TR Another trans popping out of 2nd Triumph 14
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
AngliaGT Pontiac Trans Sport / Honda Insight Spotted 1
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
skystryd Trans and Diff Spridgets 7
G Trans Axle Parts Lotus 20
tinman58 TR5/TR250 Trans slipping in reverse Triumph 38
R General Tech Preserve eng/trans that has been removed Triumph 11
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
Superwrench For Sale 62 BT-7 Trans. and OD unit for sale Austin Healey Classifieds 0
doc50 NASH METROPOLITAN trans capacity? Other British Cars 0
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
doc50 Nash Metroplitan trans swap? Other British Cars 33
Bob Claffie Spitfire Engine & trans compatability Triumph 1
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P 5spd Trans for Bugeye Sprite Spridgets Classified 14
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
S Smitty trans Master cylinder Austin Healey 21
C General MG Midget trans mounts MG 0
R TR2/3/3A Transmission fluid for 57 TR-3 Manual OD Trans Triumph 3
S TR4/4A Trans/OD gear oil? Triumph 14
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
D TR4/4A broken trans fork pin Triumph 14
C TR4/4A How to get the $&@%# filler bolt out of the side of the trans to top her off?!? Triumph 7
histerical Dat Trans Spridgets 2
bugedd Datsun 210 Trans Question Spridgets 9
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
K TR6 Thread repair for trans cover bolt Triumph 14
S TR2/3/3A driver side on the trans-cover? Triumph 11
tinman58 TR5/TR250 Trans swap Triumph 2
NutmegCT Any Borg-Warner automatic trans experts here? Other Cars 5
N Trans compatibility Spridgets 6
RAC68 Loud Trans Scrapping Noise Austin Healey 9
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
S TR2/3/3A overdrive trans Triumph 11
R GT6 GT6 trans issue Triumph 3
S TR2/3/3A Test an overdrive trans. Triumph 6
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
B TR6 Trans number decode Triumph 6
G Diff and trans oil Spridgets 8
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
RedTR3 TR2/3/3A Trans Gear lever interference Triumph 0
BlueMax Engine & Trans Finley In! Spridgets 27
