TR6 TR6 Oil Leak at rear of head - [not really]
Brosky
For those trying to fix what seem to be valve cover leaks and a leak at the back of the cylinder head that seems to come and go, I have confirmed a problem mentioned earlier in the forum.
Today, while at the Her Majesty's Service, where my shifter is being repaired, Erik and I checked my minor, but annoying, oil leak and found that it is coming from the two (2) bolts going into the engine lift bracket. Naturally, I'm glad it's not the head.
We're repairing the leak by placing copper sealing washers and the bracket. I'll report after driving if this does indeed correct the problem.
gbtr6 TR6 TR6 Oil Level, New Motor and Leak Triumph 16
A TR6 TR6 Oil Pan and head gasket leak??--help Triumph 4
A TR6 spin on oil filter for tr6 Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
M TR6 '72 TR6: Oil in Coolant Triumph 25
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
B TR6 TR6 High Oil Pressure Triumph 20
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
D TR6 Tr6 oil pan Triumph 3
A TR6 TR6 Aluminum oil gallery plugs Triumph 4
Gerry M TR6 TR6 gear oil Triumph 8
B TR6 Oil in a grease gun for TR6 lower steering swivel? Triumph 16
sundown TR6 1973 tr6 oil pressure light Triumph 3
I TR6 75 TR6 Oil Pressure Switch replacement Triumph 16
T TR6 Will a 71 TR6 oil pan come off in the car? Triumph 3
sundown TR6 TR6 oil pressure Triumph 7
TRclassic3 TR6 TR6 Leaking oil gallery plug Triumph 5
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
RomanH TR6 '74 TR6 Oil Pressure switch Triumph 7
Woodie TR6 tr6 oil change Triumph 5
Mike_Roe TR6 Oil usage - TR6 Triumph 8
T TR6 TR6 oil loss/usage Triumph 28
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
B TR6 TR6 rear axle oil change Triumph 21
B TR6 TR6 Oil Cooler hoses Triumph 1
I TR6 TR6 oil sending unit thread size help please? Triumph 12
glemon TR6 TR250 TR6 no oil pressure after rebuild Triumph 20
W TR6 TR6 Timing chain oil seal question Triumph 3
F TR6 TR6 Oil Folter Removal Triumph 10
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
mabbott TR6 73 TR6 oil pressure switch Triumph 4
I TR6 TR6 oil suggestions Triumph 9
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
I TR6 What type of oil for TR6 rear shocks? Triumph 2
T TR6 TR6 Oil Pressure Triumph 49
S TR6 priming TR6 oil pump?! Triumph 18
Brosky TR6 3-Prong TR6 oil pressure switch Triumph 13
2wrench TR6 '74 TR6 Rebuild Latest...rust in oil pan Triumph 5
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
2wrench TR6 TR6 Water in the oil; blue/gray smoke. Triumph 5
jjbunn TR6 Engine Oil Level Question - TR6 Triumph 12
hondo402000 TR6 TR6 plastic oil pressure line Triumph 2
P TR6 TR6 Oil Capacity? Triumph 7
I TR6 TR6 oil pressure information Triumph 7
F TR6 TR6 oil looks dirty soon after change... Triumph 6
F TR6 Need help w/TR6 oil cooler install... Triumph 16
