TR4/4A TR4 Wooden Dash Facia vents
E
eyesie
Hi
I am installing a replacement wooden dash on my TR4. The dash is from The Roadster Factory. I was trying to install the original plastic facia vents, which appear to just be a push in, however, they are extremely tight, to the point of them bending as I am trying to push them in, & I am afraid of cracking them. Has anyone else experienced this?
Thanks
Alan
Darrell_Walker
It may be different on the TR4, but on the 4A the vents go into the metal part behind the dash, and the wood overlays them.
E
eyesie
After doing a Google images search , I believe you are correct. It is the same for the turn signal indicator & the Ignition warning light. It looks like they forgot about these items when they added the wood.
Thanks for the response.
Geo Hahn
You got it. How the dash looks when ready for the wood:
rnpennington
I'm doin the same thing this weekend - I'll let you know how it turns out for me.
E
eyesie
Did you put Silicone or a sealant under that dash top? prior to installing windshield?
Geo Hahn
I used no sealant -- but then I live in a mostly dry climate. Once the windscreen is in place everything gets clamped down by the frame really tight.
E
eyesie
OK thanks. I am in San Diego, so no real rain issues here either. I am searching for a rheostat for the panel. Apparently the unit available is only suitable for metal dash cars, too short for wood dash. Have you come across this issue?
rnpennington
The rheostat is a very simple mechanism. What I did was to get a new rheostat, spread the tabs on the back on both and then change the shaft from the old one to the new one. Works great!
rnpennington
BTW,
Once you installed your dash - were the holes for the ignition and turn signal lights off? After test fitted mine, it looks like this:
This picture was taken straight on. Also, I had the original crash pads recovered, but this dash wouldn't fit with them installed. Fortunately, I had a replacement set from TRF and with those it fit fine??????
I'd be happy if the holes for the lights weren't so far off.
Any recommendations for other wood dashes?
Geo Hahn
Mine are nearly perfect so I never examined whether there is any wiggle room in how the light fixtures are attached.
If you add adding wood to an original metal dash - perhaps that is the cause of the mismatch (I was replacing a wood dash).
rnpennington
As there was a wood dash on it before and the paint doesn't look like it was setup as a metal dash, I am assuming it was a installed either at the dealer or early on. If it was installed at the dealer though, he had crappy woodworkers :emmersed:
HerronScott
I would check to see if there's any wiggle room on installing those lamps. How's the alignment on the rest of the dash and do you have a full picture? The amount that they are off to the right seems a bit odd since that would put the lamp hole awfully close to the gauge hole on the right and an unequal distance from the gauge hole on the left.
Scott
E
eyesie
That sounds like a good fix, unfortunately, I don't have the old rheostat.
My dash is a TRF unit, I bought off a guy. I hope the lights line up.
T TR4/4A TR4 Wooden Dash Triumph 19
pa297pass TR4/4A TR4 Wooden Dash Triumph 13
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 6
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
