Just replaced the master cylinder(from one of the big three),brake pads,rebuilt front calipers,SS brake lines,rear brake cylinders and shoes and changed fluid to DOT 5 silicone.The problem I am having is a low brake pedal on the first pump ,the second pump the pedal is where it should be and it holds there as long as my foot is on the brake even lightly.Take my foot off the brake for a couple of minutes and again low pedal on the first pump.I am not loosing any fluid and have bleed the brakes about three times.I'm kind of lost for where to go next.Any ideas would be appreciated.Thanks
