TR2/3/3A TR3A Rear Bumper
houleyh
Can anyone help me on this?
I am trying to fit the rear bumpers. The bumper bracket do not touch the distance tubes by 1 inch. Are the distance tubes too short? Is the car too long? Do I just need to bend the bracket so it reaches the distance tubes?
Any advise.
Thanks
Moseso
That's what it looks like to me. Put the bolt through there and tighten it up. See what happens...
TR3driver
Great Pumpkin - R.I.P
I dunno ... seems like the vertical part of the bracket is already at about the right angle, and closing that gap is going to angle it forward rather drastically.
vivdownunder
My car has about 1.75" of tube protruding past the bodywork, measured under the tube.
I can't remember what happens at the chassis end, but you might be able to pack the tube out with washers to get the over riders to sit correctly.
Viv.
M_Pied_Lourd TR2/3/3A TR3A Rear Bumper Distance Tubes Triumph 11
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
Got_All_4 TR2/3/3A Triumph tr3a occasional rear seat Triumph 14
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
luke44 TR2/3/3A TR3A Rear Trim Panel Triumph 7
tinman58 TR2/3/3A TR3a rear Diff seal Triumph 8
TR3Dad TR2/3/3A TR3A Loud Buzz & Rear Axel Triumph 3
T TR2/3/3A TR3A rear valance lower seam Triumph 2
M_Pied_Lourd TR2/3/3A TR3A Rear Close Out Panel Triumph 5
J TR2/3/3A TR3A rear view mirror placement Triumph 13
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
M_Pied_Lourd TR2/3/3A TR3A Rear Valence Triumph 12
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
Tinkerman TR2/3/3A Rear Valance TR3A post 60000 Triumph 6
G TR4/4A tr4 rear end in a tr3a Triumph 10
M_Pied_Lourd TR2/3/3A TR3A Rear Body Mount/Spare Tire Compartment Repair Triumph 42
M_Pied_Lourd TR2/3/3A TR3A Rear Brakes Triumph 5
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
M_Pied_Lourd TR2/3/3A TR3A Rear Axle Help Triumph 25
H TR2/3/3A TR3A Rear Bulkhead Triumph 9
ekamm TR2/3/3A Rear seat tr3a Triumph 4
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
K TR2/3/3A TR3A: Refilling rear shocks? Triumph 4
Tinkerman TR2/3/3A TR3A Rear Wing Clamp Installation Triumph 14
Tinkerman TR2/3/3A TR3A Rear Fender Stone Guards Triumph 4
M_Pied_Lourd TR2/3/3A TR3A Rear Brake Opinions Triumph 12
Got_All_4 TR2/3/3A Needed TR3A front and rear fenders Triumph 4
CraigLandrum TR2/3/3A TR3A Rear Seat Questions Triumph 13
mcguijo TR2/3/3A Clamp plate on Rear Fender TR3A Triumph 16
rlandrum TR2/3/3A TR3A Rear Axle Picture Triumph 29
J TR2/3/3A TR3A Rear Brake Cylinders Triumph 1
T TR2/3/3A TR3A rear end ratio Triumph 1
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
P TR2/3/3A TR3A Rear Crankshaft Seal Triumph 2
Don Elliott TR2/3/3A Late TR3A Rear Interior Support Triumph 11
G TR2/3/3A TR3A rear fender captive bolts Triumph 7
C TR2/3/3A TR3A 10 inch rear brakes Triumph 7
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
