TR4/4A tr4 rear end in a tr3a
gwb
hello fellow listers
i just purchased a tr3a and have rear end problems. right rear tire is outside wheelwell by about an inch and at times scraps the rear quarter panel. my mechanic says i have a tr4 rear end (that is wider) and we need to switch to correct tr3 rear end..could it just be frame is off center? how to tell a tr4 rear end from a tr3?
many thanks
billunc@gmail.com
bill browning
704-408-2711 cell
Charlotte
also, need some local advice about other correctness to this 1958 tr3a ...any triumph knowledgeable people locally , would like to pick your brain
thanks
TR3driver
Great Pumpkin - R.I.P
Andy is right of course about the TR4 axle being wider. The spring perches and everything else is the same, so the TR4 axle will bolt right up, but it moves the hubs out. Maybe you can see the difference in these two diagrams, and compare to your car. The TR3/A axle has the bulge for the inner seal very close to the U-bolt (which is located by that bump visible on top of the axle.
The TR4 axle has rather more room there, although I think the difference is closer to 1.5" than 2"
However, that should not put the axle off center, meaning both rear tires should be in roughly the same position relative to the body. 1/4" difference is probably within factory tolerance, but 1" says to me that there is something else wrong; possibly some previous accident damage that wasn't repaired properly, or mis-matched wheels.
I drove several years with a TR4 axle under a TR3A. With stock disc wheels and 165 (as I recall) tires, the tires would rub the fenders lightly only on hard turns. It polished up the sidewalls, but never damaged the tires.
Some of us are more oblivious than others, I guess ... I never noticed the difference until after I had the axle installed.
Andrew Mace
thanks
Sorry I missed this part before, Bill. You're right in the heart of Triumph Club of the Carolinas territory, and there are lots of good, knowledgeable folks in that club, some right in or very near Charlotte!
Tr3aguy
The track should be the same on the front wheels and the rear wheels. So in other words if you measure the center to center track on the front.....it should be the same for the rear......
NickMorgan
As has been said above a TR4 axle should leave the tyres in the same relative location on both sides of the car. Potentially the axle may not be located correctly. It is possible for it to be knocked back if the car has had a bit of a knock. I suppose it is possible that the axle is off-centre. You really need to do a whole load of measurements. Check that the wheels are both correct TR3, or at least matching. Same with the tyres.
The body shouldn't really be able to move on the chassis, unless it has been poorly rebuilt. Possibly the rear wing cold be misshapen.
Can you post some pictures of both sides for us to look at?
G
gwb
thanks everyone for your prompt replies
great information and we will get to the bottom of the mis alignment in the rear
glad to be on board this Triumph ship
cheers
bill browning
Charlotte
G
gwb
thanks for all your help
my complete recently restored tr3 was totaled tuesday august 10th by another driver
wish me luck
bb
HerronScott
Oh no Bill! Are you and any passengers OK?
What happened?
Scott
G
gwb
scott
every body is ok, driver is still in hospital, happy that he is ok and alive, sad about my triumph, my first triumph, and he didn't hit another car
it's a mess though
thanks for your concern
bill b
Got_All_4 TR4/4A TR4 Detroit Locker Positraction Rear End Triumph 6
T TR4/4A '62 TR4 rear end clunk Triumph 10
KVH TR4/4A TR4 Rear End Again Triumph 4
KVH TR4/4A TR4 Rear End Again Triumph 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
S TR4/4A TR4 front and rear suspension Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
M TR4/4A tr4 zip out rear window Triumph 6
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
F TR4/4A TR4 rear trim Triumph 2
Willie_P TR4/4A TR4 rear brake cyl. - what's this thingamajigger? Triumph 5
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
TR4v8 TR4/4A tr4 rear axle width Triumph 0
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
M TR4/4A TR4 rear sway bar installation Triumph 15
CinneaghTR TR5/TR250 TR4/RA/250 Rear Bumper Installation Triumph 3
R TR4/4A TR4-A rear fender Triumph 12
D TR4/4A TR4 - Rear wheel slot key removal Triumph 8
J TR4/4A TR4 rear suspension Triumph 8
TR4 TR4/4A Removing a rear fender on a TR4 Triumph 7
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
KVH TR4/4A TR4 Rear Wheel Studs Triumph 6
T TR4/4A Early TR4 Rear Suspension Triumph 22
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
R TR4/4A TR4 IRS coil over rear suspension Triumph 3
Tabcon TR4/4A TR4 Rear Brake Parts? Triumph 25
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
Tabcon TR4/4A TR4 Rear Suspension Upgrades Triumph 15
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
SCguy TR4/4A TR4 rear axle piece fell of into my hand? Triumph 21
PeterK TR4/4A TR4 Rear track bar pictures and info needed Triumph 6
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
D TR4/4A TR4 rear diff pinion seal Triumph 4
KVH TR4/4A Rear Oil Galley Plug and Flywheel Bolts TR4 Triumph 6
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Rear Brakes Triumph 1
T tr4-rear tube shocks Racing 2
P TR4/4A tr4 rear hub problem Triumph 16
