TR4/4A Removing a rear fender on a TR4
TR4
How difficult is it to remove a rear fender from a TR4? That would make working on it much easier but if taking it off creates more work than attacking issues with it in place, I will leave it on the car. I may end up painting the entire side of the car if I can't get a good match. There is a spot on the wheel well that could use some attention.
TR4nut
Yep, corrosion on the fastener may turn the job from an easy one to a real pain. If you can loosen the fender bolts, the fender will come off easily.
TR4
TR4
Thanks guys, guess I'll pull the bumper and tail light off and see how easy it is to loosen those fender bolts. Getting the fender off will also allow a look at what lies beneath.
hondo402000
I had a spot on my TR6 hood, was only going to paint the hood now 6 months later almost finished painting the entire car
Hondo
glemon
It is just bolted on, but it should be mentioned that the bolts are mostly up in a tiny narrow place that have little room for wrenches and your hand, because of the course threads on the bolts that hold the fenders on I have not had much trouble getting them off, but the bolt/nut that holds the bumper on on the sides and goes through the fender is another story, I think there is a spacer, it is usually rusted on solid. I have had much trouble with those on the couple of cars I have done the operation on. Use much penetrating oil before you start.
I think I have ended up cutting something in most cases
66healey removing rear fender Austin Healey 3
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
busybrit Removing the drain tube fron the rear mains cap. Austin Healey 4
R Removing rear quarter elliptical Spridgets 5
pkmh Removing Rear Hub on BJ8 Austin Healey 48
M Having a hard time removing the rear bumper [pic] Triumph 4
TR3MT Removing rear fenders Triumph 10
drooartz Removing the $@#! rear hub oil seals Spridgets 3
Ohiobugeye Whats the key to removing the rear radius arm bush Spridgets 6
Guinn removing rear rubber bumper MG 6
T Help removing the rear drive flange Triumph 2
HAN8L1965 Removing backing plate on rear drum brakes Spridgets 3
sultanoswing T-Series Removing Rear Hatch - tight screws!! MG 1
bluemiata90 Removing rear springs Triumph 3
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
