TR2/3/3A Topping off rear shocks on TR3
M
Member 10617
How do you check and top off the fluid in the rear shocks of a TR3? The new shocks available from Moss for the TR3 don't have the filler plug on the top of the unit that the TR2 appears to have had, and that the TR4A solid axle suspension has.
Geo Hahn
I guess I've never seen what they sell as replacements. The fill plug on the originals (mine anyway) is on the side though up near the top.
TR3driver
Great Pumpkin - R.I.P
Ditto. If they don't have that plug, I suspect you'll have to remove the shock from the car and remove the top cover. I would add the plug at the same time (being careful not to let any swarf loose inside the unit).
BTW, IIRC the original plug is a Whitworth size.
sp53
I would not worry about it. The shock sounds like a sealed unit. If there is fluid coming out, get a new one. I would not break the factory seal only out of curiosity.
M
Member 10617
There's no fluid coming out, so the units seem to be OK.
Manual instructions say that the units should be checked and topped-0ff every 12,000 miles, so that is why I have looked into it.
The plug appears to be on the inside, near the top (and not on the top), as George has pointed out.
George: Have you ever topped-off your units? If so, what procedure did you use (jack up the car, etc., etc?) Does part of the procedure include pumping the unit for possible air in the fluid.
mgbmedic
My car is a 58 and it is filled from inside the car. There are plugs under the carpet for access. I'm not sure on post 60,000 cars with the flat rear shelf.
Geo Hahn
When I pull the wheel off I'm looking right at the plug -- so perhaps mine is different form yours. I just use a little squeeze bottle with a pointy tip that I keep filled with shock oil. All I'm doing is adding a bit until it runs out to be sure it's topped up so I do no pumping.
I just do it whenever I'm doing the usual rear maintenance (oiling the springs, adjusting the handbrake, lubing the bearings, checking the shoes. etc).
TR3driver
So, how does that work? Your shocks have the plug in the top and the hole in the body is in the slanted part of the "shelf"?
I've owned several pre-60K TR3/As, and they have all had the plug in the side of the shock, accessed behind the rear wheel.
M
Member 10617
George: Just what I needed to know. I'll use a squeeze bottle and fill it just as I fill my transmission: fill until it flows out (finds its proper level naturally) and then replace the plug.
My one concern was whether, when opening the plug on the side, if the unit was not positioned properly, the fluid might be forced out in some way. I have read in another forum posting that when some guy opened his plug, the fluid "shot out." Someone who answered him suggested that someone had overfilled the shock and pressure had built up.... I assume, from what you have written, that I don't have be concerned about this or position the unit or the lever in any special way, other than to jack up the car and remove the wheel.
With the VA DOT hard pressed for funds, our roads are becoming rougher to ride. Thus, need for fully functioning shocks... (ha, ha)
Randall: Many thanks for the photo! These ALWAYS help.
BTW. I see now in the Moss catalog illustration of the rear shock absorber that the plug is shown, but not labeled. Every other component is labeled, but not the plug. Go figure?
TR3driver
That is a blow-up from Practical Hints 6th ed. Good reference for any TR3 owner (although the 6th ed was for post-60K cars). Reprints are available from TRF, I believe.
M
Member 10617
Hi, Randall,
Thanks. I have the manual (an original copy, in fact), but that's the one manual I didn't consult when trying to figure out where the plug is located. Should have known...
Geo Hahn
LexTR3 said:
...With the VA DOT hard pressed for funds, our roads are becoming rougher to ride. Thus, need for fully functioning shocks...
Though these cars ride surprisingly well with no shocks (or I should say a shock that has become unbolted). Makes a heck of a noise though.
Geo Hahn
There is a purpose-made oil sold by the usual vendors though I use fork oil sold by local motorcycle shops. That oil comes in specific weights so you may want some advice on what weight to use.
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
floyd topping off gearbox and rearend fluids Triumph 13
edkap2002 TR6 Topping up cd175 Carbs Triumph 8
58Custom How often should carb damper oil need topping up? Spridgets 4
K TR2/3/3A Old school battery shut off switch....... Triumph 3
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
B TR4/4A Headlights Blink Off Triumph 15
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
kodpkd Signing Off Austin Healey 8
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
T Knock-Off Spinners Austin Healey 43
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
G Engine Will Not Turn Off Austin Healey 10
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
T TR4/4A Fenders off the car for paint? Triumph 8
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
R Turn Signal Knob goes off center Austin Healey 9
J BJ8 flywheel take some pounds off Austin Healey 17
A Setting Camber Really Off Austin Healey 13
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
S TR2/3/3A Frame off vs. body on restoration Triumph 21
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
B TR4/4A Can't get rear extension off. Help! Triumph 24
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
JPSmit Off to bed for the winter Spridgets 10
TomMull Knock Off Tool Restoration & Tools 6
S MGB When your breaks off. who ya gonna call......? MG 2
L Tight spot on steering box is way off Austin Healey 18
R TR4/4A Speedometer off 10mph Triumph 6
Boink MGB MGB-GT off-roading? MG 4
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
J Gas pump auto shut off question Austin Healey 2
Got_All_4 TR6 How does this steering lock come off Triumph 9
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
Got_All_4 TR6 Rear Panel Reflector off a parts car? Triumph 8
D TR2/3/3A off topic , but can you help with a quotation Triumph 5
T TR4/4A Heater control valve - cant completely turn off Triumph 3
JPSmit Off to British Car Day Spridgets 8
D cut-off switch Austin Healey 20
D TR2/3/3A curious tachometer take-off Triumph 5
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Jim_Gruber New Shoes, New Shoes Bugsy got to show off his new shoes today. Spridgets 6
jfarris TR2/3/3A Off the shelf oil filter Triumph 9
A turn signal knocked off center Austin Healey 14
