Top Frame Repair - ideas needed
RJS
Hi
So, the front header rail on my top frame cracked from metal fatigue on the front right side where it has a large rivet connecting it to the side frame. This is at the upper right side of the windshield frame.
I'd like to weld the repair. But, I am afraid the heat will melt the top in that area. So, can I remove the vinyl top from the header rail, make the weld, and successfully reattach the top to the header rail without damaging it? I did not install this top and have no experience installing tops. My understanding is that the top is glued and riveted to the header rail. Can I remove vinyl top from the header rail without destroying it?
Here are pics
For perspective, the broken spot is right in the center of the picture
Here is how it used to look before it cracked
And here is the cracked (I highlighted the crack with a white pencil)
Any ideas?
Thanks
PS: sorry the photos are so small - my first time posting pix. If you click on the picture, I think it will open a larger version.
glemon
I am not sure about the top, I have put them on, but haven't taken one off, especially after it has been mounted a long time, but you should be able to carefully strip the top off the header rail after removing the retaining strip. A little heat might help loosen up the old adhesive. What is the plan for repair, a weld? leaving the frame on the car, or taking it all off. I also have a spare TR4A top frame that has been in the garage rafters in for, like, ever, and would be willing to part with it, but shipping wouldn't be cheap from Nebraska.
alanjohnturner
I've welded almost everything on a TR at least once. This is easy.
With MIG the heat spread wont be more that about 1in, 2in at absolute maximum. But there will be spatter which make spin-holes in things. You should see my trousers.
So cover everything with wet cloth or Aluminium cooking foil or both. There are prper welding blankets for this kind of job. Work well but not cheap.
You will need to get the vinyl away from the frame for a couple of inches/
I would take that rivet out rather than trying to weld over/around it.
It always take thickish stuff back on a 45 angle so I weld in the V.
Clamping this will be tricky. I'd get an assistant to hold it put on a few small tacks before the finish weld.
RJS
RJS
I would take the whole top off the car to work on it. Pretty sure I can repair with a weld but, thanks for the offer on the top frame. I have access to a MIG. I had no idea the heat would stay so localized. I'll see what he says. And thanks for the idea of wet blankets and notching a V in the weld.
RJS
RJS
Update...successful repair. Alan, thanks for your tips and encouragement.
My brother owns a MIG welder. I removed the top from the car (10 minutes max). Took up to his house. Isolated the crack and blanketed the whole rest of the top with wet towels. With an angle grinder, we notched a V in the crack to give the weld more clean material to hold on to. We were not able to remove that large rivet even after grinding the top off and hitting it hard with a punch.
Anyway, here's the weld. Probably stronger than new.
Thanks again
dklawson
Great!
Even though you think the weld is stronger than new, always treat that area delicately like it is about to break. The transition around a weld zone can be somewhat brittle and that area on the frame is bound to be stressed a bit.
cheseroo
FWIW, I've found that an old aircooled VW input shaft has a somewhat close to correct concaveness (is that a word?) to match that rivet head. If the header rail is too floppy, a block on one side of the rivet and a BFH smacking the input shaft on the other tightens things up. Just a random discovery.
wkilleffer Top frame removal and repair MG 6
bill_young Folding top frame repair. Spridgets 2
B TR6 TR6 convertible top frame Triumph 0
zoohow BN4 Top Frame Installation Austin Healey 1
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
JamesD BJ8 Top Frame Bumpers Austin Healey 12
C 100/6 BN4 Soft Top Frame Austin Healey 16
dbenichou289 TR2/3/3A top frame bracket Triumph 7
B Longbridge BN4 top frame question Austin Healey 6
P top frame fit Spridgets 5
RAC68 Top Frame platform location measurements Austin Healey 0
RAC68 Top Frame, Hard to Weld Austin Healey 13
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
G TR4/4A Top Frame Paint Recs Triumph 12
warwick-steve BT7 soft top frame location Austin Healey 6
E Wanted WTB BT7 top frame Austin Healey Classifieds 3
I BJ8 soft top frame dimensions Austin Healey 4
C Top frame pinching soft top - BJ8 Austin Healey 6
aero3113 Wanted 100-4 Top and frame Austin Healey Classifieds 8
Rut TR4/4A TR4a or TR6 top frame? Triumph 4
TR3TR6 TR6 TR6 top frame windshield seal. Triumph 5
Marla TR4/4A Soft top frame Triumph 13
Rut Top frame and boot panels Spridgets 2
Lutz Kramer Top Frame Austin Healey 4
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
C TR4/4A TR4A top frame buffer Triumph 3
Rut Top frame storage brackets Spridgets 3
tomshobby New way to Install gasket between soft top and windscreen frame. Spridgets 2
B Top frame adjustment Austin Healey 6
Jeepster Folding top frame spring Austin Healey 12
G MGB mgb convertible top frame width MG 5
Jim_Gruber Brackets to hold top frame on a BE Spridgets 22
TR6oldtimer TR6 TR6 soft top frame not aligning with windows Triumph 1
Bob McElwee '66 BJ8 Phase III Top Frame Assembly Austin Healey 3
J TR2/3/3A Convertible Top Frame question for tR3 &3A Triumph 7
BJ8Healeys TR2/3/3A TR3A top frame straps Triumph 13
BJ8Healeys TR2/3/3A TR3A top frame color Triumph 11
Jeepster Folding soft top frame Austin Healey 7
S BN4 top frame needed Austin Healey 5
T Is this a Bugeye top frame? Spridgets 9
drooartz Is this normal -- top frame when folded MG 9
drooartz Sourcing snaps for folding top frame MG 9
F Spitfire Replacement Of Spitfire Convertible Top Frame Seal Triumph 6
Lotuswins Top Frame Powdercoat? Austin Healey 5
H TR4/4A Cover For Top Frame on TR4 Triumph 8
R Top frame question Spridgets 1
D Rag Top frame for 100-6 question Austin Healey 8
J BE top frame to borrow-Fla? Spridgets 10
