tire pressures
Arch 93
My '55 100-4 has 165 R15 86S tires on front and 165 R15 86T tires on the rear. Would appreciate any recommendations as to the correct tire pressure(s).
Thanks in advance.
ThomP
I run "modern" pressures in my modern tires: 32 LBs front and rear. They wear properly and the handeling isn't as heavy as the "antique" recommendations in the shop manual or drivers handbook.
Anyone else agree/dis-agree????
Randy Harris
Agree - 32 lbs at each corner (Yokohama A321 185.70.15)
Randy
A
Arch 93
Thanks for your help, guys. Since we're having very unseasonably warm weather here, getting air in the tires will be a good excuse for a drive tomorrow.
Thomas
Editor_Reid
Platinum
[ QUOTE ]
[/ QUOTE ]
I don't know about "correct" tire pressure, but I like to run at the maximum recommended pressure, as shown on the tire sidewall. This gives best performance, at least in dry conditions.
Yes, it would be high for wet conditions, but I don't drive "spiritedly" in the wet. For that matter, I don't drive my Healeys in the wet at all, if I can possibly avoid it.
Yes, it increases tire wear a tiny, tiny bit, but if you're that concerned about tire wear, you shouldn't own/drive a performance/sports car.
On the other hand, there's nothing wrong with 32 PSI - or something close to that - for a good, general-purpose inflation pressure.
Keoke
Hi TomSpeer, Neglecting performance and considering driver comfort only. I would suggest a pressure of 28 PSI given you are running the series 80 tires on original width rims..--Fwiw--Keoke
Dave Russell
Yoda - R.I.P
Atmospheric pressure at 6,500 ft would be about 79% of what it would be at sea level.
For the same "actual" pressure, the tire would be inflated more at higher altitude.
HOWEVER, simple tire pressure gages would also read higher at higher altitudes, & the two changes would likely compensate for each other. Result - No change.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Hi Reid,
My below statements are general statements. Optimum tire pressures will depend on the exact car, exact tire design, & intended use.
Running max sidewall rated pressure will likely not hurt anything on RADIAL tires, except for a harder ride. Inflating BIAS PLY tires above the pressure needed for the load WILL cause the tires to hump up in the center & reduce the contact patch.
On radial tires, higher inflation pressures usually increase the tire's grip. The BN1, BN2 with it's more rearward weight bias can be better balanced - oversteer/understeer - by higher pressure, more grip in the rear, lower pressure in the front. With a 3/4" front sway bar, I find that 28 front, 32 rear gives more neutral handling. Keeps the rear from coming out as much.
The sixes with more front end weight usually work better with more equal front & rear pressures.
The very low original "book" pressures for bias ply tires are too low for modern radials & will give much reduced stability. OTOH, Higher pressures in bias ply tires will just make them hump up in the center & reduce the contact patch. As you say, it depends on the tire & it's intended use.
Johnny
I am using Dunlop 165SR/15 86S type tires. I tried 32 psi and found the ride very hard and undesirable. By lowering the psi to 28 it seems to make a difference in less harshness. I also found that by running at higher psi the sidewall developed a depression in it that I didn't care for, but not on all 4 tires. It might have been a defect in the tire but at any rate I chose to lowere the psi, the depression didn't change all that much but it made me feel safer anyway.
/ubbthreads/images/graemlins/driving.gif
T TR6 TR6 Tire Pressures Triumph 2
K TR2/3/3A Randall...Re: tire pressures Triumph 10
D BJ8 Tire Pressures Austin Healey 13
Michael Oritt Tire pressures Racing 7
eejay56 Autocross tire pressures Racing 6
T Tire [tyre!] pressures Spridgets 1
Gundy Tire pressures? Spridgets 10
TRcheologist Tire Pressures Triumph 6
aeronca65t Race alignment-tire pressures? Racing 3
KLUTZ Different tire pressures? Triumph 3
S TR2/3/3A Tire balance Triumph 15
J MGB Tire pressure for 1980 MGB MG 14
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
Healey Nut Tire Sizes Austin Healey 10
F TR2/3/3A Spare tire cover Triumph 3
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
G Rear tire scrubbing!!? Spridgets 23
H Can a 175x13 tire be fitted on Bugeye Spridgets 6
M TR5/TR250 Compatible Modern Tire Size Triumph 5
L TR2/3/3A tire manufacturing build date Triumph 2
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
J TR6 Tire Recommended for TR6 Triumph 3
S TR2/3/3A tr3 spare tire fit Triumph 16
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
L General TR tire age code Triumph 3
H TR2/3/3A Original Dunlop 5.50X15 Bias Ply Tire Data Triumph 4
AUSMHLY Wheel Tire Camber Austin Healey 57
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
O TR2/3/3A Spare tire Triumph 4
