Tire pressure
Nelson
I'm wondering if today's tires use the same pressure as the original tires used. My owner's manual says 18 front and 20 rear for regular use. Are those numbers the same for modern tires?
Those would be a little low for a set of modern radials. I'd start at 26 psi and work from there.
Nelson
Nelson
Thanks. I thought they sounded low to me but 26 sounds better. My experience of driving my Sprite ended 39 years ago and I figured things have changed. Now if only I could drive it again. The only thing keeping me off the road is my missing carbs. Joe Curto has had them seven weeks and I'm getting really antsy.
jlaird
need about two lbs less in front than rear for Max cornering potential.
Nelson
Nelson
Thanks, Jack. That goes along with the difference given in my manual.
Pythias
I'll have to pump up my tires.... I've been running 22/24 just for the comfort. ..Should I run even higher for extended freeway time as per "the book"?
Pythias
bigjones said:
Do you see uniform wear across the tread pattern?
That is an interesting question. Personally I can't wear out a set of tires. Almost anything you can buy today is wear rated to last 50,000+ miles. That's over 7,000 miles a year across the seven years of a tires "safe" life span. Plus, these cars are so much lighter than the cars for which the tires are rated, they're likely good for well of 70,000 miles. Heck I even considered having a set shaved.
________________________________________________________________
Ok, I pumped 'em up and went for a drive. I have a slightly harsher ride, but not as bad as it was before I changed the rear springs. The car does feel a little "lighter on its feet" and seems to roll down the highway with less effort. I think I'll keep it this way. I can hardly wait to get fuel economy readings.
aeronca65t
One thing I'd suggest: check your tire presures HOT and not COLD.
Your tires are hot most of the time (when is use), so it makes sense to get them up to temp before checking.
I'm running around 28-30 psi hot in my street car with radials (not a Spridget......it's an MGB).
As stated, those old tire pressure specs are for bias tires and not radials. Bias tires always run less pressure.
For comparison, Spridget racers who run on the latest Hoosier TD bias race tires typically run around 26 psi (hot).
On the other hand, those of us who race on DOT radials run much higher. I run around 38 to 40 psi (hot) in my Toyo 888s.
R
RonMacPherson
:driving: Wheeh, you had me wondering at first if you were gonna recommend heat gun across the tread surface setup... Remember poking the rubber at the track for setting tire pressure.(That should give you some idea of how old I is). :bow:
J MGB Tire pressure for 1980 MGB MG 14
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
NutmegCT T-Series tire pressure? MG 8
NutmegCT tire pressure gauge accuracy Restoration & Tools 21
NutmegCT TPMS - Tire Pressure Monitoring System Other Cars 9
sundown TR6 TR6 tire pressure Triumph 4
T TR2/3/3A tire pressure Triumph 18
bighealeysource Tire pressure recommendations for tubed tires Austin Healey 4
Nelson Autocross tire pressure?? Spridgets 4
R Glove box tire pressure plate Triumph 5
G Auto cross tire pressure Spridgets 7
1 Tire pressure MG 8
AUSMHLY Correct tire pressure Austin Healey 8
bighealeysource tire pressure with radials Austin Healey 11
D tire pressure question Triumph 8
wkilleffer Good tire pressure for 18570R14 tires on a '74 'B? MG 19
bighealeysource Tire pressure Austin Healey 2
jlaird Tire pressure Spridgets 5
jlaird Lets get serious=tire pressure Spridgets 18
TRclassic3 Tire Pressure Triumph 9
J Tire air pressure Triumph 9
S Tire Pressure and Additives Jaguar 16
A Dumb tire pressure question MG 9
MadRiver Tire pressure? Triumph 8
vping Tire pressure MG 15
C TR2/3/3A TR3A Tire Pressure Triumph 6
Brosky Tire pressure question Triumph 24
P Correct Tire Pressure for 165R15... Austin Healey 2
J tire air pressure MG 6
S TR2/3/3A Tire balance Triumph 15
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
