Dumb tire pressure question
aroostok
Anybody tell me what tire pressures to run in 175/70 R14's on the 76 B? Tried going by recommendations in one of the manuals I have and appears way too low - I can burn rubber at 10 mph!
Thanks
Platinum
I've always run at 28 front, 32 rear. Higher by a couple pounds now and again but always the four pound differential front-to-rear. It keeps a slight oversteer this way.
This B is an earlier car, so a bit lighter than yours.
Steve_S
The pressures in the manuals work best for Bias Ply tires. On modern radials you should be running between 27 and 32 PSI. Typically M.G.s handle best with 2 PSI more in the rear than in the front. The wider the tires go, the more equal it seems the pressures can be. I would start with 28/30 and experiment from there.
Platinum
The pressures I posted above are for the 175/70 R14's I've run for years.
I run 30 lbs all around, but I don't do any high performance cornering or anything.
PAUL161
[ QUOTE ]
Thanks
[/ QUOTE ]
You know, that's like asking 15 people if they all like the same ice cream. To me, it depends on the tire and how you intend on driving it. I have Veridestien Quadtracs, 165/70/14s on my 72 and run 28 lbs front and rear. If I wanted to run it a little more aggressively, I would add more air to the rear. But it's real comfortable as is and a pleasure to drive. So that's my flavor. /ubbthreads/images/graemlins/jester.gif PJ
danmas
If you look at a graph of tire grip vs tire pressure, you'll notice that grip goes up pretty fast as you approach the optimum pressure, and falls off rather slowly as you increase pressure beyond the optimum. ie, too much is better than too little, within reason, of course.
Probably the best thing to do is play with pressures until you find what suits you the best.
Rob_P
[ QUOTE ]
[/ QUOTE ]
yeah, but anyone who doesn't say chocolate should not be trusted....
Steve_S
There is a perfect pressure to run for every vehicle. But what that pressure is depends on many, many factors including tire construction, tire materials, road surface, road conditions, temperature, driving style, vehicle weight, suspension set up, wheel type, wheel size, desired ride quality, etc, etc, etc. I run 30/30 on my '65 B, 29/31 in the '58, and 30/32 in the '67. Sometimes I take it down one or two PSI. It just depends on which of the aforementioned factors are most important at that particular time.
LAW75 Stories of "I Can't Be THAT Dumb" Austin Healey 37
AngliaGT MGB Dumb Question - What's This Part? MG 3
B TR4/4A Dumb Bumper questions Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
tahoe healey Dumb carb question Austin Healey 23
Darwin Spitfire Dumb Question Triumph 2
M MGB trying to change rotors - dumb question MG 7
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
NutmegCT Dumb bolt question Restoration & Tools 7
D TR6 Dumb question Triumph 2
D TR2/3/3A Dumb question Triumph 3
B MGB Dumb emergency brake questions...help requested! MG 5
D Dumb question Triumph 5
60TR3A Dumb Newbie Question Austin Healey 16
wingsandwheels Dumb mistake...nice drive w/ e-brake on Triumph 6
E another dumb electrical question Austin Healey 8
Jim_Newman dumb little electrical question Austin Healey 3
richberman Dumb SU fuel pump question? Austin Healey 9
M Dumb Dumb Question about Drum Brakes [pics] Triumph 10
B At the risk of sounding dumb..... Triumph 4
NutmegCT dumb antifreeze question Restoration & Tools 4
Sarastro Quick dumb transmission question Spridgets 9
Tugboat Dumb Question re: Battery Triumph 15
T TR4/4A 62 TR4, new owner, [dumb ]question about cyl head Triumph 15
Jim_Gruber My Dumb Present Owner moment Spridgets 24
Frankenhealey Dumb de dumb dumb DUMB [Portentious music!] Austin Healey 0
C This might be a dumb question but.... Spridgets 15
tahoe healey Dumb-dumb Austin Healey 10
T Can I powder coat this stuff or will it look dumb? Spridgets 10
T I think I did a dumb thing Spridgets 14
TR6oldtimer TR6 TR6/250 water pumps and a dumb PO [me] Triumph 4
I TR6 A few dumb TR6 brake questions Triumph 9
Pythias Dumb Present Owner Spridgets 20
S Will Basil kick me off for dumb questions...? MG 9
M A Dumb, but Necessary, Question Spridgets 11
Grampy 72 Midget Dumb questions for the day Racing 7
Yngbld14 Dumb Question MG 0
Yngbld14 Dumb Question Spridgets 2
StupidHippie Really dumb diff mount question? Triumph 12
2wrench Dumb question I gotta ask Triumph 2
walshja OK, I did something dumb Spridgets 24
jlaird Dumb question Spridgets 2
E TR6 TR6 Diffy - Dumb ? But Thought I'd Ask Anyway Triumph 4
judow Dumb Question? Jaguar 5
tony barnhill Dumb Late Night Question Spridgets 8
Tinkerman Did a REAL Dumb Thing!!!! Triumph 7
G So here's a dumb question Triumph 20
M T-Series Dumb MG TD badge bar fitment question MG 4
