Tire pressure
111
I did not get an owners manual with the car, and have not yet tracked one down for my car. Anyone know the tire pressure that is recommended?
Mickey Richaud
I'm running 28 front/30 rear. Owner's manual said considerably lower, but I think the pressures I'm running are more in line with modern tires.
rggav
Member
I just bought some wire wheels with Sumitomo tires from Hendrix tire. They recommend 28 psi front and back. The official handbook recommends much lower. If you are running high speed for a trip, I would bump it up 1 or 2 psi.
Mickey Richaud
From memory, my '73 manual says 22 front and 24 back.
111
:crazyeyes: Wow that is low, even for a '73
I assume the 1980 is not much different, but that just does not seem like enough air.
I guess if you run between 28-32 without uneven tread wear it will be ok. I have 32 all the way around at the moment and the tires look good. However I think I might bump it down a few psi based on the responses so far.
Steve_S
Ignore the owner's manual. That was for tire technology of the 60's and 70's. Tires today are constructed differently, and the correct pressure for your tires will depend on many factors including tire construction, driving style and environmental conditions. The typical MGB runs approximately 28F/30R give or take a couple PSI. I run 29/32 in one MGB and 30/30 in another. The difference is tire size, stiffness, rubber compound and more weight over the rear wheel on one of them (GT versus roadster).
When I bought my MGB, the PO had the tires inflated to 50 front and rear! :eeek: Dropping the pressure to 28f/30r seems like the tires are half inflated.....
Platinum
28/32 here.
J MGB Tire pressure for 1980 MGB MG 14
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
NutmegCT T-Series tire pressure? MG 8
NutmegCT tire pressure gauge accuracy Restoration & Tools 21
NutmegCT TPMS - Tire Pressure Monitoring System Other Cars 9
sundown TR6 TR6 tire pressure Triumph 4
T TR2/3/3A tire pressure Triumph 18
bighealeysource Tire pressure recommendations for tubed tires Austin Healey 4
Nelson Autocross tire pressure?? Spridgets 4
R Glove box tire pressure plate Triumph 5
G Auto cross tire pressure Spridgets 7
Nelson Tire pressure Spridgets 10
AUSMHLY Correct tire pressure Austin Healey 8
bighealeysource tire pressure with radials Austin Healey 11
D tire pressure question Triumph 8
wkilleffer Good tire pressure for 18570R14 tires on a '74 'B? MG 19
bighealeysource Tire pressure Austin Healey 2
jlaird Tire pressure Spridgets 5
jlaird Lets get serious=tire pressure Spridgets 18
TRclassic3 Tire Pressure Triumph 9
J Tire air pressure Triumph 9
S Tire Pressure and Additives Jaguar 16
A Dumb tire pressure question MG 9
MadRiver Tire pressure? Triumph 8
vping Tire pressure MG 15
C TR2/3/3A TR3A Tire Pressure Triumph 6
Brosky Tire pressure question Triumph 24
P Correct Tire Pressure for 165R15... Austin Healey 2
J tire air pressure MG 6
S TR2/3/3A Tire balance Triumph 15
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
