TR6 TR6 tire pressure
sundown
Is anybody running 205 /70 tires on their TR6? Question is what should the tire pressure be for the front and rear tires cold? Thanks
poolboy
When this gets asked, I don't know that I've seen 2 alike.
Mine are usually 31 rear, 28 front.
I have run 31 or 32 all around.
glemon
I don't know the correct answer either, I am still getting to know my IRS car's handling after running many LBC's with solid axles and leaf springs for years. Are you looking for handling or a smooth ride? I would run about 28 all around for general tooling around in comfort, and maybe more like 32 psi if you like to whip it around the corners a lot. I am not really sure what is best front to rear.
Geo Hahn
As one might conclude from the above -- no one right answer. I can tolerate a harsh ride for the handling I prefer so I tend to go pretty high on the pressure with the rear tires usually about 2 lbs higher than the front.
Maybe start at 32psi and see how it drives, then go up or down from there. I know of no reason why you cannot go as high as you like so long as you do not exceed the pressure shown on the sidewall.
T TR6 TR6 Tire Pressures Triumph 2
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
J TR6 Tire Recommended for TR6 Triumph 3
Scot1966 TR6 Screws in TR6 spare tire well Triumph 12
I TR6 69 TR6 spare tire lid Triumph 4
bcbennett TR6 TR6 Tire Clearance Triumph 3
B TR6 TR6 Tire Advice Triumph 6
B TR6 Putting a 205 75 tire on a tr6 Triumph 4
bcbennett TR6 TR6 Spare Tire Triumph 27
R TR6 TR6 Spare Tire Cover Needed Triumph 9
MTribe TR6 TR6 tire size photos? Triumph 30
bigbadbluetr6 TR6 TR6 Spare Tire Triumph 1
N TR6 Opinions on 205-70R15 tire size for TR6 Triumph 11
I TR6 TR6 - uneven tire wear in rear tires Triumph 1
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
F TR6 TR6 Tire Recommendatios Triumph 12
AngliaGT TR6 TR6 Tire Replacement Triumph 6
B TR6 Yes.....another TR6 tire size question Triumph 7
R6MGS TR6 Another TR6 Tire Thread Triumph 21
B TR6 Question about tire size options on a TR6 Triumph 3
SpannerMan TR6 TR6 jack minimum height for changing a tire? Triumph 5
Brosky TR6 Looking for tire advice for TR6 Triumph 17
T TR6 TR6 Tire Sizes - Modern Equivalent to 185 SR 15? Triumph 13
T TR6 Tire Preservation Question - 1976 TR6 Triumph 13
Z TR6 TR6 Tire Recommendation? Triumph 5
SCguy TR6 Tire suggestions for a TR6/Panasports Triumph 4
B TR6 My TR6 rear tire tilt inwards at top Triumph 9
Cain TR6 TR6 Tire Size Triumph 10
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
