T-Series tire pressure?
NutmegCT
Now that I've got new P165/80R15 radials (all weather, nothing fancy) on the (original steel disk) wheels, I wondered what tire pressure is recommended. Everyday driving up to 50mph, curving two-lane blacktop.
The tires were installed at 30 psi. The original bias ply tires were recommended at 18 psi.
I just took my first drive on the new tires at 30 psi. Just barely turning the steering wheel turns the car faster than I expect. Really sensitive steering, so I'm careful I don't oversteer. Would lowering the front tire pressure reduce that "oversteer" tendency - maybe 24 psi front, 26 psi rear is better for the TD (under 2000 lbs)?
Thoughts?
Tom M.
Gliderman8
Lower pressure = more friction, more wear.
Just my thoughts.
number6
When I last changed the tires on the Spitfire, the garage set them at 32 all the way around. It made for a much harsher, bouncy ride. Not sure if less wear and tear on the tires is worth it
for more wear and tear on me. Reset them to 21 and 26, which is more comfy and I can live with.
NutmegCT
NutmegCT
Thanks gentlemen. I've been googling on and off all day for some way to calculate what psi is advisable, based on weight on the axles, tire size, driving style, etc. Surprised there are so many "just keep trying different pressures until it feels right" replies. Actually surprised so many car guys say "just use what's on the side of the tire". (Yikes! pressure on the side of the tire is *maximum*.)
Funny, but I completely agree with the "keep trying different pressures" suggestion. But at a minimum, that takes a lot of time. You'd think there'd be a way to actually figure a starting point based on weight of car, then adjust up or down from there.
There's got to be some rationale for Nissan labeling "33 psi" for their recent Altima cars, or GM labeling "36 psi" for the Volt.
Thanks.
TM
Sarastro
The pressures specified for the original tires are useless for modern radials, and probably even modern cross-bias, classic-car tires.
I'd start at 30 psi, as you have; it should work OK for just about everything. If it seems harsh, try reducing the pressures all around by, say, 2 PSI at a time. Or, if too soft (which I doubt), increase it incrementally. Then, when it seems OK in that regard, you can try experimenting with different pressures front to rear.
It's really not a big deal. If it's too much for you, I'd just set them at 30 psi and leave it that way.
Of course, others who have gone through this exercise with their TDs might chime in with info on the pressures they are using; that might be a better starting point. FWIW, if I remember correctly, I used 28 psi all around on my TD.
NutmegCT
NutmegCT
Exact-a-mundo! Learning what pressure(s) other TD drivers are using - and how they came up with what they chose - would be a great help.
Tom M.
pdplot
My article that I sent you brings up the tire pressures - 18 lbs. was recommended and was ridiculous. To add to the understeer, I would try 25 front and 28 back. Would ride a bit harder but handle much better.
NutmegCT
NutmegCT
Paul - this weekend I used 26/28 and was really happy with the handling. Big improvement, and no oversteer.
Thanks again for the advice.
Tom M.
PAUL161
Tom M.
:encouragement: :driving:
J MGB Tire pressure for 1980 MGB MG 14
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
K TR2/3/3A Tire pressure and ride comfort? Triumph 9
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
NutmegCT tire pressure gauge accuracy Restoration & Tools 21
NutmegCT TPMS - Tire Pressure Monitoring System Other Cars 9
sundown TR6 TR6 tire pressure Triumph 4
T TR2/3/3A tire pressure Triumph 18
bighealeysource Tire pressure recommendations for tubed tires Austin Healey 4
Nelson Autocross tire pressure?? Spridgets 4
R Glove box tire pressure plate Triumph 5
G Auto cross tire pressure Spridgets 7
Nelson Tire pressure Spridgets 10
1 Tire pressure MG 8
AUSMHLY Correct tire pressure Austin Healey 8
bighealeysource tire pressure with radials Austin Healey 11
D tire pressure question Triumph 8
wkilleffer Good tire pressure for 18570R14 tires on a '74 'B? MG 19
bighealeysource Tire pressure Austin Healey 2
jlaird Tire pressure Spridgets 5
jlaird Lets get serious=tire pressure Spridgets 18
TRclassic3 Tire Pressure Triumph 9
J Tire air pressure Triumph 9
S Tire Pressure and Additives Jaguar 16
A Dumb tire pressure question MG 9
MadRiver Tire pressure? Triumph 8
vping Tire pressure MG 15
C TR2/3/3A TR3A Tire Pressure Triumph 6
Brosky Tire pressure question Triumph 24
P Correct Tire Pressure for 165R15... Austin Healey 2
J tire air pressure MG 6
S TR2/3/3A Tire balance Triumph 15
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
