Timing gear on camshaft sprocket question
Bruce_B
I'm putting a double-chain adjustable timing set onto my 1275. The sprocket on the cam fits on nicely and cam endfloat is fine.
Trying to put the gear onto the cam shaft and having a hard time, seems like its just to tight. I remember pulling off the original one and that wasn't easy either - took some screwdrivers and leveraginga little bit at a time till it came off.
Any hints/tips of getting the gear on? Would a few taps with a rubber mallet hurt anything?
dklawson
The timing gear is a snug fit. I must admit that I cheat a bit and run some wet/dry paper around the bore of the pulley (especially around the keyway) before trying to fit them... just in case there are any burrs.
Bruce_B
Bruce_B
Welll, after trying for about 1/2 hour I measured the crank and the bore of the gear---The gear's bore is to small, by about 2 thousandth. Only way that's going to fit
is after a trip to the machine shop.
In my spare box of parts I had a crank timing gear in good shape so used that. The adjustable cam timing gear is a wondererful thing.
Just emailed Swiftune in the UK. Right now I've got an expensive paperweight.
Thanks for the help.
dklawson
Swiftune? SW5?
I don't wish to suggest anything negative about Swiftune, but you may find you need to telephone them. When I bought my SW5 I had several questions and my emails went unanswered.
Sorry about the clearance issue. However, I think you'll like the Swiftune cam... assuming it's the SW5.
Bruce_B
Bruce_B
Yup the SW5. I've had good luck with emailing them, fast replies. I wondering what, if anything they'll do for me on this problem.
dklawson
I'm glad you've had good email success with them. Admittedly, my contact with them was over 4 years ago. A lot changes in 4 years.
Is it their timing gear as well as their cam? If so, I'd like to think they'd replace one or the other... or perhaps they have a partner in the U.S. who they'd authorize to bore the pulley out for you. The one who comes to mind is Seven Enterprises. They now distribute Swiftune products and they have a machine shop.
You'll like the cam. I found it gives nice low end torque with lots of pull up through the range I use my engine.
piman
Hello Bruce,
how did you measure the bore of the camwheel, bores are tricky to read accurately.
If it is 2 thou too small, then perhaps warming the wheel would get it on but make it very tight to remove. I'd put a tight wheel into a pan of oil on the stove to warm it, by the way.
Alec
P.S., removing 2 thou also needs a good machinist, you are talking about removing one thou off the inner face.
Bruce_B
Bruce_B
Alec,
I just did the best I could with a micrometer. If I do go to a machine shop, I'll bring the gear that fits and tell him to bore out the one that doesn't fit so its the same size.
This way he can do the measuring that's needed.
thanks........
KVH TR4/4A No Marks on Timing Gear Triumph 30
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
C Wanted Timing gear cover 1275 Spridgets Classified 2
R timing gear crank shims Austin Healey 11
Scott_Hower TR6 TR6 crank/timing gear quality issue? Triumph 2
TulsaFred Timing Gear positioning on 1275 Spridgets 7
rikiwho123 timing chain to gear drive? Triumph 4
KVH TR4/4A TR4 Timing and Distributor Gear Triumph 3
2wrench Back in the saddle with timing gear questions. Triumph 9
A adjustable timing gear sprocket Triumph 16
A Crankshaft timing gear Spridgets 2
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
vette Timing Marks! Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
vette MGB 74 1/2 Timing Specs. MG 16
B Timing Light question Austin Healey 0
F TR6 Timing adjustment Triumph 13
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
D BT7 Timing Advance Austin Healey 17
D BT7 ignition timing Austin Healey 5
R TR2/3/3A Timing Triumph 3
