Those dashed darned brake calper bolts
middie
I have been trying to remove one bolt from my RHS brake caliper for about 3 weeks now (on and off) and haven't even budged it. I tried heat, grinding, swearing (at least I felt a lot better) and JP's magic ATF/Acetone mix - nothing worked.
All I ended up with was some grooves in the back of my caliper, but it didn't penetrate so the caliper should be OK.
Then I had a chat to Colin Dodds at Sprite Parts ( https://www.spriteparts.com.au/ ) and he let me into a little secret. Weld another bolt to the top of the stuck bolt, and the heat will expand and crush the rust and the stuck bolt will virtually drop straight out.
Guess what? It worked like a dream. I can always count on Colin for those little trade secrets when I'm in trouble.
Wazza
Deleted member 8987
Rusty bolts and heat, old trick I use still. Heat the bolt, expands into the rust, breaks it up, and out it comes.
Run a tap in the hole, use anti-seize, and it will be fine.
equiprx
I'm not so sure about using anti-seize on brake caliper attachments. If anything, you need to use Locktite.
Westfield_XI
The caliper mount bolts are secured with steel tabs bent over the flats of the bolt heads. Thread locker is unnecessary.
equiprx
Well if that's the case, never mind.
A TR2/3/3A Those round fuel line clips Triumph 2
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
jlaird MGB For those who were excited with me. MG 2
tr6nitjulius General TR Those were the days Triumph 4
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
S TR2/3/3A source for those little drain hoses Triumph 6
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
S TR2/3/3A On those old original coils Triumph 2
S TR2/3/3A Those chrome 4 bolts Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
NutmegCT Loosen those nuts! Restoration & Tools 5
HealeyRick Those Were the Days Austin Healey 11
Joe Reed General MG One of those "duh" moments... MG 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
alanjohnturner TR6 for those planning a new paint job Triumph 3
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
drooartz General Tech Check those brake hoses! MG 11
WillR For those thread nerds. Restoration & Tools 23
5 I used to own one of those Spridgets 6
S TR2/3/3A Those colored frames Triumph 4
M Those cork washers on either side of the kingpin... Spridgets 9
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
Basil General MG For those who remember Tony Barnhill MG 25
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
S General TR Those who think Victoria British is slow getting our TR parts to us Triumph 10
CJD One of Those Days Triumph 15
P those infernal thrust washers Triumph 11
S TR2/3/3A those metal button trim pieces tr3 Triumph 5
rick_ingram Check those splines! MG 7
L For those who know the difference Lotus 5
DrEntropy Where'd THOSE come from?!? Spotted 6
JohnnyMead Can't Get the Air Out of Those brakes! Triumph 8
Gundy Oh no...I've become one of those Spridgets 25
Got_All_4 Wedge Going to look at one of those yucky brown TR7's th Triumph 25
D One Of Those Nights Triumph 4
PATR8 It is just one of those weeks Triumph 8
B Those little tiny screws Triumph 4
Timd For those who like data and statistics Spridgets 6
K Those who switched back to points from petronixx.. Triumph 64
PatGalvin Tie Down Those Brake Lines to the Diff Triumph 4
zedvictor1 Those fender holes behind the RB Spridgets 6
roscoe One of those moments Austin Healey 0
T For those about to weld Triumph 3
pjsmetana Those darn Battery Terminals! Triumph 16
T OT - but for those of us doing body work scary Triumph 12
deadair TR2/3/3A For those who's TR3s are up on blocks Triumph 14
