Those darn trunk[boot] cavities
WALTER
Those cavities between the trunk and fender bug me. They aren't rusty enough to replace, but I do want to stop the rust that's there. So I was thinking of soaking it with rust converter then filling it with resin. How wacko is that?
Thanks,
Walter
Biff
Walter,
Sand the rust as best as possible then use rust converter and cover that with a coat of paint (car color). Filling it with resin won't help any more than painting and painting would be cheaper.
sqbsprite
POR-15 works very well in an area that will not be exposed to UV so it will not require a top coat. You can paint over it if you choose. It's available in white,black,silver or grey. It will get into the crevices and seal it so no new rust can form. I prefer it over the rust conversion stuff.
John Moore
Yes, please don't use resin. If you have to repair it properly in the future, that would be a super huge mess to clean up.
tosoutherncars
I would say, rust converter, then a rust-preventive paint (I use Eastwood's Rust Encapsulator). Top-coat in body colour if you like.
See my other posts for similar treatment to my inner fenders and floor, with good results.
WALTER
WALTER
I think I'll dredge it with some One-Step by Mar-Hyde and call it good. I think it is like POR-15. It's too tight to sand, maybe a bottle type brush and the compressor.
Thanks,
Walter
WALTER
WALTER
Now that I look at it again........is that inner panel really necessary? What would be so wrong with cutting it out then sealing off that narrow slot? Then it could be properly prepped and painted. Two less places for rust to hide. YES, I know it won't be original!
Outside the box,
Walter
WALTER
WALTER
I really would like at least one opinion on this.
W
Bugeye58
Yes, the inner panels are necessary.They add stuctural rigidity to the entire rear section. Including, ultimately, the rear spring attachments.
It's your car, do what you want to it.
Incidentally, the reason the round wheel arch cars were changed back to square arches was that the semi ellipic rear springs loaded the structure differently, and there was a possibility of failure.
Jeff
vping
Bronze
DPO of my midget filled it with "Great Stuff" Spray foam. He also tried to use it as a glue for the rear speaker panel. Mo-ron.
B those darn trunk lids!!! Spridgets 11
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
pjsmetana Those darn Battery Terminals! Triumph 16
A TR2/3/3A Those round fuel line clips Triumph 2
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
jlaird MGB For those who were excited with me. MG 2
tr6nitjulius General TR Those were the days Triumph 4
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
S TR2/3/3A source for those little drain hoses Triumph 6
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
S TR2/3/3A On those old original coils Triumph 2
S TR2/3/3A Those chrome 4 bolts Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
NutmegCT Loosen those nuts! Restoration & Tools 5
HealeyRick Those Were the Days Austin Healey 11
Joe Reed General MG One of those "duh" moments... MG 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
alanjohnturner TR6 for those planning a new paint job Triumph 3
drooartz General Tech Check those brake hoses! MG 11
WillR For those thread nerds. Restoration & Tools 23
5 I used to own one of those Spridgets 6
S TR2/3/3A Those colored frames Triumph 4
M Those cork washers on either side of the kingpin... Spridgets 9
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
Basil General MG For those who remember Tony Barnhill MG 25
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
S General TR Those who think Victoria British is slow getting our TR parts to us Triumph 10
CJD One of Those Days Triumph 15
P those infernal thrust washers Triumph 11
S TR2/3/3A those metal button trim pieces tr3 Triumph 5
rick_ingram Check those splines! MG 7
L For those who know the difference Lotus 5
DrEntropy Where'd THOSE come from?!? Spotted 6
JohnnyMead Can't Get the Air Out of Those brakes! Triumph 8
Gundy Oh no...I've become one of those Spridgets 25
Got_All_4 Wedge Going to look at one of those yucky brown TR7's th Triumph 25
middie Those dashed darned brake calper bolts Spridgets 6
D One Of Those Nights Triumph 4
PATR8 It is just one of those weeks Triumph 8
B Those little tiny screws Triumph 4
Timd For those who like data and statistics Spridgets 6
K Those who switched back to points from petronixx.. Triumph 64
PatGalvin Tie Down Those Brake Lines to the Diff Triumph 4
zedvictor1 Those fender holes behind the RB Spridgets 6
roscoe One of those moments Austin Healey 0
T For those about to weld Triumph 3
