Thermostat ugliness & temp range recommendation
tdskip
So, taking your advice for things I should do while the car looks like this;
I pulled the water outlet once I got the inch thick blue sealer off it;
Which exposed a thermostat which looked like this;
And the inner housing;
What temperature range thermostat would you recommend for the new one?
Would you replace the water outlet housing? It's pretty corroded on the neck and has lots of lumps on the inside from corrosion as well that can't be helping coolant flow.
Thanks!
G
I would. I don't have an A series, but I'd say 180 deg. There are differnt thoughts on this (in other engines). Some will go to 195 for fuel economy, other 160 for spririted driving. Someone with allot more knowledge of these engines will chime in. Whatever you do, flush all of that crap out good !!! I'd change the studs too, possibly to bolts.
walshja
In the northeast, I had to put a 195 degree thermostat in to ensure the car reached proper temperature.
it had a 180 degree in, and in the winter I could never get the car up to proper running temperature, and I had no heat. swapped in the 195 degree, and the car warms up much quicker both in the summer and winter, and I have nice hot heat blowing on my legs in the winter.
from a few article I have read, you need you engine to reach proper temperature to burn off contaminates in your oil, which would otherwise build up when you engine never reaches that proper temperature.
Jim_Gruber
Time to replace those studs with bolts. A whole lot of prep work with PB Blaster for a few days, try tighten first and then loosen the studs. On my 1098 they all came out without any issues.
HAN8L1965
I'm using the standard 180 from VB no complaints. You can also get new studs and housing from them. I did go through 3 new housings before I got one that did not leak from pin holes in the casting. I would pull the lower left block plug and the heater contron and flush the heck out of that block and radiator before putting back together. Be careful after installing new studs and slipping the housing down that everything is nice and flat and don't tweak the studs too much. Oh the lessons learned!
Mark
T
tdskip
Good consideration Mark - thanks for posting that.
Guys - are the new castings all suspect you think, or was mark just extra lucky? Would tracing down a NOS/used one be a better idea?
Billm
No comments (nor knowledge) about the castings but if you are looking for a thermostat the common Chevy ones for the 6 or 8 cylinders ('60's thru '80's and beyond) fit perfectly and are easier to get (at your local parts house).
BillM
walshja
BillM
that is just what I did !! $5 for the gasket and themostat
Sarastro
Wow! Ug-lee!
Really need to clean that stuff out. The thermostat opening temp is pretty much irrelevant until you do. Since it's in the engine, it's probably in the radiator too. So everything will need to be purged and cleaned.
But to answer your original question, mine is 165 degrees, only because that's what the guy who restored the car put into it. I'd suggest using something a little higher, as it seems to take quite a while to warm up completely.
T
tdskip
walshja said:
BillM
Have a part number or reference by chance?
T
tdskip
Sarastro said:
Wow! Ug-lee!
Nasty, eh? On my honor this didn't happen on my watch. LOL.
How would you guys clean this, just flushing with water wouldn't seem to cut it here.
I had a spare OE replacement radiator recored, so I'm good there.
G
tdskip said:
walshja said:
BillM
I use to know all that crap off the top of my head. "They're all the same" 1957 to whenever they quit the SBC...which I can't remember that either.
I've got the HP one in mine, cost $12 but is visible better made.
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Twit TR4/4A shining up thermostat housing Triumph 9
Lin Thermostat and blanking Sleeve question again Austin Healey 7
R TR2/3/3A Thermostat and bypass hose Triumph 15
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
AUSMHLY BJ8 Thermostat Austin Healey 4
Healey Nut Thermostat blanking sleeve Austin Healey 13
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
D BT7 Thermostat Austin Healey 1
D BT7 thermostat gasket Austin Healey 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
C Corrosion of the thermostat cover Austin Healey 8
R TR2/3/3A Correct Thermostat? Triumph 7
O TR2/3/3A Thermostat housing Triumph 3
AN6-TX 948 Thermostat Housing Spridgets 11
S TR2/3/3A Bellows thermostat for tr3 Triumph 11
steveg Robertshaw sleeved thermostat Austin Healey 3
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR2/3/3A used thermostat Triumph 5
B TR6 Which thermostat TR6? Triumph 3
P Overheating after shut down & recommendation on thermostat Austin Healey 3
R correct thermostat Austin Healey 3
steveg Thermostat questions Austin Healey 44
R Thermostat revist Austin Healey 11
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
R looking for Moss 363-370, 1500 thermostat housing Spridgets 13
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
J TR4/4A TR4a Thermostat Triumph 2
GBT remove thermostat MG 11
K TR2/3/3A Who is running a Sleeved Thermostat in their TR3? Triumph 16
Anthony_S Thermostat Triumph 4
M 99 XJ8 Thermostat Housing Failure Jaguar 0
Skip_Shervington TR2/3/3A TR3A Thermostat Housing Leak Triumph 6
Morris Thermostat vs. Pinging Spridgets 14
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
M Headremoval and thermostat.. Austin Healey 3
R Need more heat - which thermostat MG 15
RJS Thermostat Stuck Open? Triumph 11
Darrell_Walker Wedge TR8 hoses, thermostat, etc Triumph 2
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
BugeyeNJ58 Geo Metro Radiator - need thermostat housing Spridgets 10
Westfield_XI What if the thermostat was in upside down? Spridgets 9
D Thermostat Austin Healey 37
T TR2/3/3A TR3 thermostat rating Triumph 4
M T-Series Thermostat Switch Question MG 11
BugeyeNJ58 Thermostat question - is it needed in hot weather? Spridgets 5
