Folks,
Every since the engine rebuild on my TR3A, I have had over-heating problems which have not been solved by a new aluminum radiator and the Macy’s Garage fan.
On the advise of a friend, I have decided to replace my original-style sleeved thermostat with a more “modern” Robert Shaw high-flow thermostat.
My question is do I need to block the bypass hose? My friend blocked the bypass hose on his TR3A by inserting a copper plumbing cap into the bypass hose, with a small diameter hole drilled in the cap to allow some coolant to flow through the copper cap.
Thoughts?
Thanks.
Ron
Thoughts?
Thanks.
Ron
