TR2/3/3A Question on TR3 thermostat from TRF
TuffTR250
The online TR3 catalog at TRF has only 2 choices of thermostat for TR3...the original bellows type and what is described as "modern type". The catalog says that the "modern type", p/n GTS104, can be used if the bypass hose to the radiator is blocked. I currently have a copper plumbing plug in my bypass hose, however based on information I got from some forum, I drilled a small hole in the middle of the plug (1/8" or 3/16" as I recall). Based on the TRF catalog statement, to use the TRF thermostat, should I replace the bypass hose plug with one that has no hole in it? Thanks!
Bob
Merlin63Tr4
The plumbing plug with the hole will work just fine.
M.
TR3driver
Great Pumpkin - R.I.P
IMO, no, not unless you drill a hole in the thermostat.
With the bypass blocked and the thermostat closed, there is almost no water circulation. But there is still the usual amount of heat put into the water around the exhaust valves, so the coolant there can get a lot hotter than the thermostat setting, even boil, before the water at the thermostat gets hot enough to open it. Then when the thermostat finally does open, there is a rush of still-cold water (potentially below freezing in cold weather) into the near-boiling (or even higher) cast iron cylinder head. The sudden thermal shock can result in cracks.
The GTS104 type thermostat actually became the standard thermostat later on, and is listed as a factory-approved supercession for the earlier type. The thermostat housing was slightly redesigned, mostly I suspect to make it easier to cast, but the new casting did have a slightly smaller bypass passage.
I've experimented several times with my own cars; I found no real-world difference in cooling between fully blocked and fully open.
My current cooling system is not stock (mostly electric fan and an overflow bottle), but I have no cooling issues whatsoever even in 115F ambient temps, with the bypass fully open. (The driver overheats before the car does, at 115F I start looking for someplace cool to wait for the sun to go down.)
sp53
I use a sleeved thermostat which I believe they came with and with that I have a tropical fan. I also have a bellows thermostat that I took out of car that was a barn find which is made in England and maybe original. I can tell by looking the sleeved one is going to do what they are both designed for which is blocking the bypass hose for warm up more effectively. Not sure which one is truly correct. If you are having over heating problems, it is probably the fan. If not the fan, the radiator has plugged lines.
Andy Blackley
sp53
Yeh I saw the movie ---Fail Safe---I always call Moss motors with my problems, but we seem to be on different pages.
5 TR2/3/3A TR3 fender patch panel question Triumph 10
T TR2/3/3A TR3 Fuse Question Triumph 14
T TR2/3/3A Question on old radio from my TR3 Triumph 9
S TR4/4A TR3/4/4a Transmission rebuild question Triumph 7
71TR6 TR2/3/3A TR3 floor pan to firewall question Triumph 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
D TR2/3/3A TR3 water pump question Triumph 4
BillyB62 TR2/3/3A TR3 timing/distributor question Triumph 7
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
T TR2/3/3A Question on paper air filters for TR3 Triumph 3
K TR2/3/3A TR3 body fitting question.... Triumph 3
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
Tinkerman TR2/3/3A 1960 tr3 a upholstery question Triumph 2
J TR2/3/3A Convertible Top Frame question for tR3 &3A Triumph 7
M TR2/3/3A Carpet question 1956 TR3 Triumph 9
T TR2/3/3A tr3 bulkhead holy question Triumph 13
Lbp TR2/3/3A Question about TR3 Rubber Windshield Seal Triumph 9
Lukens TR2/3/3A TR3 SU carb question Triumph 10
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
T TR2/3/3A Question on side seal on TR3 fender seal plate Triumph 1
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
M TR2/3/3A TR3 fuel cap install question Triumph 9
T TR2/3/3A TR3 floor / frame mounting point question Triumph 13
Lbp TR2/3/3A New to Forum, New TR3 Owner, Dashboard Question Triumph 8
M TR2/3/3A One more steering question TR3 Triumph 4
Tr3aguy TR2/3/3A Hubcap Question TR3 Triumph 15
D TR2/3/3A TR3 brake rotor question Triumph 4
J TR2/3/3A TR3 oil pressure hose question Triumph 1
Russ Austin TR2/3/3A TR3 Transmission question Triumph 8
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
mgedit TR2/3/3A 56 TR3 Door Question Triumph 8
NutmegCT TR2/3/3A TR3 engine question Triumph 6
M TR2/3/3A My own TR3 windshield question? Triumph 5
toysrrus TR2/3/3A TR3 Interior Question: Triumph 5
PatGalvin TR2/3/3A TR3 Door Rebuild Weatherstripping Question Triumph 10
F TR2/3/3A TR3 interior mystery question- door pull handles Triumph 9
M TR2/3/3A TR3 Tail light question Triumph 4
M TR2/3/3A TR3 gas cap question Triumph 4
K TR2/3/3A TR3 Trunnion Question Triumph 2
J TR2/3/3A TR3 fuel pump question Triumph 7
R TR2/3/3A TR3 Headlight Wiring Question Triumph 6
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
C TR2/3/3A New member and newbie question on TR3 clutch Triumph 26
M TR2/3/3A TR3 steering column mounting question???? Triumph 2
Brooklands TR2/3/3A TR3 Turn Signal question... Triumph 6
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
toysrrus TR2/3/3A Re: TR3 thread question again. Triumph 2
