TR2/3/3A Question on side seal on TR3 fender seal plate
TuffTR250
I bought the side seal for the fender seal plate on my TR3 from Moss, p/n 680-410. Which side goes on the plate, is it the side with the shorter slot? Also, the seal is so stiff that I can't bend it outward so that the plate bolts will fit, and if I leave it straight out from the plate, the holes don't even come close to matching the fender holes. How do I go about fitting the side seal? Thanks!
Regards,
Bob
CJD
Bend the top rubber forward so it will seal tighter when water hits it. The side seal splits for and aft on the plate, and best to bend forward to fit the wing contour.
S Steering Wheel Side to Side Movement Question Austin Healey 6
B Side window question for early Longbridge BN4 Austin Healey 4
F Austin Side shift transmission question Austin Healey 0
T Question regards Insurance for members on other side of the Atlantic Austin Healey 2
steveg Side Curtain Flange question Austin Healey 5
T TR2/3/3A Question on TR3A aftermarket side curtains Triumph 8
toysrrus TR2/3/3A Re: Side Curtain Question Triumph 4
glemon TR5/TR250 Triumph TR250 Trivia, Side Molding Question Triumph 7
ShawnC_at_Moss Question for you Bugeye guys regarding trunk side panels Spridgets 20
bighealeysource Tranny question on BN2 side shift Austin Healey 6
G Side screen top question Triumph 4
doughairfield Side Mirror Question Triumph 9
Tinkerman Side Curtain Color Question Triumph 10
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
