Good call on those 3 punch marks groupdeville; the last time I put a steering wheel on the nut had those punches , and they can effect the torque because I was not sure what I was feeling, the wheel snug or the punch marks maybe stripping the threads. The shaft has a taper fit to match the wheel and the splines, so clean everything up good and then tighten the nut with maybe someone holding the wheel to help. I do not know of a torque, maybe 25.
After you get the wheel tight enough for you--- work the wheel some back and forth then push it in and pull back a little in and out or maybe drive the car some before you put the stator tube back. I put the stator back in once right away then in a couple of days I could feel a little back and forth click with the wheel. What happened was I did not get the wheel nut tight enough by about a Ā¼ turn or the shaft taper was dirty or whatever, but I had to pull it all apart to tight that Ā¼ turn to stop the click.
steve
