Steering wheel offset
Goldie
During restoration and a realignment of the front end, my steering wheel (Moto Lita) is off about 10 degrees. How complicated is it to actually get it straight. Can I pull the horn hub and move the wheel mounting hub or am I into pulling the entire trafficator assembly.
Adjustable or non-adjustable wheel? If it's adjustable, and you have enough slack in the wiring you should be able to pull the hub out a few inches, remove the snap ring and replace the wheel (make sure the wheels are pointed straight ahead before pulling it). With a non-adjustable wheel you have to loosen the olive and pull the whole stator tube, and you'll lose most or all of your steering box fluid, so you might as well drain if first. Also, the non-adjustable wheels are secured with a large nut, and you need to be able to put a socket on it.
G
Goldie
Its adjustable but the locking ring is on so tight I can't move it. I think it is reverse thread but not sure. I don't want to force it and make it tighter. The guy that restored it had never done a big healey--only triumphs and MG's.
My experience is with exactly two Healeys: My BN2 is non-adjustable and has a large nut securing the wheel, and my BJ8 has an adjustable wheel. I always assumed the adjustable wheels had the snap ring and the non-adjustable the nut, but I've not worked on any of the intervening cars. If it's a nut, it's probably right-hand thread; the only LHT's I know of on a Healey are the hubs/knockoffs on one side of the car, and on the 100s one of the knurled knobs securing the foldable windshield it LHT. I don't know how you'd make an adjustable wheel with a lock nut, but maybe someone else can chime in here.
John Turney
When you're sitting in the driver's seat, turn the locking nut clockwise to loosen it. It's a right-hand thread.
Rob Glasgow
Bob provided the correct procedure. After you've loosened the wheel locking ring, loosen the 3 grub screws on the wheel hub and pull up the entire trafficator mechanism. Now push the wheel all the way down on the streering shaft to expose and remove the snap ring. Now you can pull the wheel off the shaft enough to move it right of left one thread which should be about 10 degrees.
Unfortunately my wheel is off only about 5 degrees, so if I reposition it one spline notch left or right, the center spoke is still not straight up. I guess I'll need to mess with the tie rod setting to get it perfect.
GregW
Platinum
My comment is useless to this thread, but the right door check strap has a left hand nut (and bolt).
Rob Glasgow
Bob, I've always thought the design of the door check mechanisms was a brilliant, low tech solution and the guy who came up with that was a genius. I've wondered if it was used on other cars besides the Healey. Anyone know? Sorry to step on this thread.
Jack T
Add the nut on the input shaft of the gearbox.
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
K 1968 Midget Steering wheel Spridgets 1
Editor_Reid Wrapped Steering Wheel Austin Healey 9
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
kodpkd Leather Steering Wheel Cover Austin Healey 3
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
LAW75 Derrington Steering Wheel Austin Healey 19
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
A Austin A40 trafficator steering wheel Other British Cars 5
T Steering Wheel Adjustment Range Austin Healey 0
R TR2/3/3A Steering wheel hub removal Triumph 11
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
J Steering Wheel Repair Austin Healey 32
Walter74 Adjustable steering wheel removal Austin Healey 4
D TR2/3/3A Shaking in steering wheel above 50 mph. Triumph 19
D Steering Wheel Repair Austin Healey 2
K For Sale TR3A Steering wheel Triumph Classifieds 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
Exotexs For Sale 1968 MG-B steering wheel and handbooks MG Classifieds 0
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
S Steering Wheel Side to Side Movement Question Austin Healey 6
Ripper01 SOLD-TR6 Steering Wheel for sale Triumph Classifieds 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
S Wedge tr7/8 quick release steering wheel Triumph 0
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
R Wanted wood steering wheel Jaguar Classifieds 0
K TR2/3/3A The Steering Wheel Nut Triumph 20
AUSMHLY Adjustable steering wheel removal Austin Healey 5
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
angelfj1 TR2/3/3A How to restore a bluemels steering wheel Triumph 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
