19_again
Well here's another fine mess. I took Mr B out last weekend, had a nice drive and parked in the garage. As is my habit I always check the gas gauge when I pass by the car just to see if the battery is still ok. it was fine up until Wed., when it was dead. Hadn't taken it out since the weekend, nothing left on. This has happened once before. I put the jumper to it, the gas gauge cam eback to life, turned the key and he started right up. Ran about ten minutes, and died. Dead Battery. Ignition light comes on at low rpms, goes off as rpms increase. New harness going in over winter, but concerned it may be something else. Could bad alternator cause slow drain?
BTW here's the pix I've been promising.
https://www.villagephotos.com/pubbrowse.asp?folder_id=1938735
Mike
Mike
