Suspension Repair in Mid-west
jmason
I am seeking recommendations for a good suspension repair shop in the mid-west. Close to Chicago and Tiger experienced preferred!
Steve
Platinum
British Auto Service in Milwaukee, WI might be worth a try. They work on obscure stuff (steering rack for a Rover P5) so they may be what you need. Number is (414) 273-0007. Nice guys, Craig and John are the owners. If not, try Sportscar Services in Mequon, WI. (262)238-1133, speak to Bill. Good luck, let me know how you get on.
Steve
MikeP
It's about 5 hours away but Tiger automotive in Dayton Ohio has been working on Tigers and doing restorations since the cars were new. The owner, Doug jennings is a member of TEAE and a good guy.
thegoodbeamer
I would try Tiger Auto in Ohio
J
jmason
Thanks for the replies. I found a British car repair shop in Elgin, IL (LaFox Automotive)that is near me, and they agreed to work with Doug Jennings at Tiger Auto. Doug is going to straighten the crossmember. I might take the opportunity to upgrade the fulcrum pins to the 4140 units he sells. I hope to be Tigering by September!
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
PATR8 Rust Repair on Suspension of my 8 Triumph 3
L Front suspension repair MG 1
M TR2/3/3A Rebuilding suspension Triumph 29
K TR6 Rule of thumb for frt suspension shims Triumph 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
P Suspension upgrade for a A40 Devon. British Motor Corp 0
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
L TR6 MII Suspension Triumph 6
R TR6 Rear suspension droop restraint Triumph 0
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
Healey Nut BT7 Rear Suspension Austin Healey 15
D MGB Rear Suspension Damper Link Arm MG 2
R TR6 Front suspension fulcrum pins Triumph 6
Michael Oritt Evaluating Suspension Components Austin Healey 4
Upland Mark IV front suspension Spridgets 3
JPSmit Suspension question Spridgets 1
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
M TR6 suspension puzzle Triumph 3
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
L 100/6 tuning and suspension ugrades advice Austin Healey 7
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
bugedd Winter Suspension Project Spridgets 7
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
M Creaking rear suspension Austin Healey 13
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
S TR4/4A Coil-over suspension upgrade Triumph 4
P TR6 tight suspension Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
HighAltitudeTR3 TR2/3/3A Saggy suspension? Triumph 5
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
