TR6 suspension puzzle
masked
Hey, after two years of replacing parts: bushings, shocks, springs, brakes, brake lines and a few other things i got the car going recently and have found a problem after going over bumps in the road that sounds like something is loose, I went in and tightened everything down, I did discover that i had the spacers on rear springs on top that was wrong and put them on the bottom of the springs, and it did improve the ride a lot. My question is do you think putting the rear sway bar back on would help as well as alignment improve the ride? Any suggestions would be appreciated. Thanks, Milt
M
masked
I am having the alignment worked on at a shop, i did realize one of the lever shock bolts wasn't as tight as i thought it was, i will be taking it back out soon to test it again, I am also putting the anti sway bar in the rear back on to see if that helps with the situation. Thanks for your comment.
Gliderman8
Loose bolts on the lever shocks are common and cause a clunking sound. I had the very same problem. Put the car on jack stands and tightened the bolts and problem solved.
M TR2/3/3A Rebuilding suspension Triumph 29
K TR6 Rule of thumb for frt suspension shims Triumph 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
P Suspension upgrade for a A40 Devon. British Motor Corp 0
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
L TR6 MII Suspension Triumph 6
R TR6 Rear suspension droop restraint Triumph 0
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
Healey Nut BT7 Rear Suspension Austin Healey 15
D MGB Rear Suspension Damper Link Arm MG 2
R TR6 Front suspension fulcrum pins Triumph 6
Michael Oritt Evaluating Suspension Components Austin Healey 4
Upland Mark IV front suspension Spridgets 3
JPSmit Suspension question Spridgets 1
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
L 100/6 tuning and suspension ugrades advice Austin Healey 7
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
bugedd Winter Suspension Project Spridgets 7
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
M Creaking rear suspension Austin Healey 13
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
S TR4/4A Coil-over suspension upgrade Triumph 4
P TR6 tight suspension Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
HighAltitudeTR3 TR2/3/3A Saggy suspension? Triumph 5
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
Rut TR4/4A Suspension and drivetrain components Triumph 3
D TR4/4A badly stuck suspension sleeves Triumph 7
