TR6 MII Suspension
Low'n slow
Member
Bronze
I'm thinking of a Mustang II suspension swap on my 75 TR6.
Plans are for a 2JZ engine and transmission. I already have the Nissan rearend upgrade.
Good plan, or talk me out of it?
poolboy
I've seen it done...but the entire TR 6 frame was reconstructed....Chevy V8 & automatic trans, Ford rear
Have you been to this Forum ?
mgNOT
I have a TR6 with Ford small block, and modified my TR6 chassis.
I don't recall any examples of a TR6 swap with a Mustang II front suspension
grafted, which is not to say it cannot be done. Every swap involves considerable
re-engineering by the person doing it. I would think that going to a Ratco or Fast Cars
aftermarket chassis might be a better solution. Both of those are well sorted, and would
stiffen the car. The TR6 is very narrow, will the Mustang suspension fit, or would
the wheels be outside the fender-I mean wings? The general consensus is that the rear of
the TR6 chassis is the weakest part so that will have to be addressed.
The 2JZ is not the most common swap into a TR6, but there are a couple at least.
My decision to go with the Ford was it had been done before, was relatively short
(using Explorer engine), modification parts for the engine were plentiful and would increase
performance without going full-on racer. My fear with the 2JZ would be the length.
I know nothing about that engine, so maybe I'm speaking from ignorance, but engine intrusion
into the passenger compartment was something I tried to avoid. Some have done various V6's,
but I felt that if I was going to the trouble, I would go for a little more performance than a moderate upgrade.
-Dennis
Tybalt
I have no idea with respect to using the Mustang II or even Pinto front suspension on a TR6. Regarding the Toyota engine, there are different flavors of the 2JZ engine, normally aspirated (2JZGE, 2JZGE-VVTi (normally aspirated with VVT) and then there are the 2JZGTE engines that are turbocharged and the later 2JZGTE-VVTi. I did find some dimensions for the 2JZGTE. From https://www.supraforums.com/threads/need-physical-dimensions-of-2jz.403696/ post #8:
OK, I have an Aristo 2JZ-GTE in my garage right now, waiting for a swap. I just ran down and took the measurements.
Head
8 1/4" wide (edge to edge)
30" wide (edge of stock twins to edge of intake manifold)
Engine
31" long, pulleys to starting edge of bellhousing (end of block)
27" tall, bottom of pan to top of valvecover
Oil sump
11" long, starts 5" back from edge of pulleys
13 1/2" wide
Hope that helps, PM me if you need anything else.
Dave
I would suspect that most dimensions would be the same between the GE and the GTE variants with the exception of width since it looks like width includes the twin turbochargers and intake manifold. I do know that a BMW inline six swap has been done many times. Here is a link for a BMW S50 engine transplant into a TR6:
The owner of this car is/was on here as milemarker60 (last post Oct 2008, also same user name on the British V8 forum) if you want to try and follow through on the build process, just be aware that it looks like the pictures are now gone. There had also been pictures on a British site that morphed from a Austin Healey, MG, Triumph site into "The MG Experience." While new posts could not be made about anything other that MGs, they kept the Austin Healey and Triumph stuff archived but when I just checked to see if any of the pictures were there, they have now killed those archives. Not a good thing as there was a wealth of information in those archives. I'm going to have to dig into the Wayback Machine some time and see if they archived any of that stuff.
L
Low'n slow
Member
Bronze
Yes, I have been there. I see mustang coilovers mentioned, but no mention of the cross member etc...
L
Low'n slow
Member
Bronze
Our 2jz is not turbocharged. It looks Ike a better fit than the 1uzfe that we were going to use.
I have significant help on the engineering side as my brothers built cars for a living.
I appreciate the input.
M TR2/3/3A Rebuilding suspension Triumph 29
K TR6 Rule of thumb for frt suspension shims Triumph 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
P Suspension upgrade for a A40 Devon. British Motor Corp 0
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Rear suspension droop restraint Triumph 0
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
Healey Nut BT7 Rear Suspension Austin Healey 15
D MGB Rear Suspension Damper Link Arm MG 2
R TR6 Front suspension fulcrum pins Triumph 6
Michael Oritt Evaluating Suspension Components Austin Healey 4
Upland Mark IV front suspension Spridgets 3
JPSmit Suspension question Spridgets 1
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
M TR6 suspension puzzle Triumph 3
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
L 100/6 tuning and suspension ugrades advice Austin Healey 7
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
bugedd Winter Suspension Project Spridgets 7
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
M Creaking rear suspension Austin Healey 13
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
S TR4/4A Coil-over suspension upgrade Triumph 4
P TR6 tight suspension Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
HighAltitudeTR3 TR2/3/3A Saggy suspension? Triumph 5
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
Rut TR4/4A Suspension and drivetrain components Triumph 3
D TR4/4A badly stuck suspension sleeves Triumph 7
