Suggestions For Drilling A Hole in your EYEBALL
Tabcon
Like an imbecile, I was grinding away on my old block last night with no eye protection on.
Somehow, (I wonder how that happened) I got a very small bit of cast iron in my right eye. It itched and burned all night long, so I went to my eye doctor today to have him remove it. Well, after about 20 drops of different solutions in my eye, he skillfully plucked it out. Then he reached into his Yurick of York tool box and pulled out an eyeball drill. "This may hurt a little", he said. No @#$% I said. It seems that when you get metal in your eye, it begins to rust immediately and along with the nasty bits of metal, you have to remove the rust stains as well. So there you have it, I had my eyeball drilled today.
Red Hot Poker
Wear your goggle boys!
K
KSIS
I cut the roof off a Montero and thought I had it vacuumed out well enough, even hosed it out. As I was driving to work a filing flicked up and caught me in the eye.
I have felt your pain!
Gliderman8
I too have had the pleasure of getting steel in my eye when I was in my late 20's. Fast forward to just a few years ago and I had to get an MRI. They gave me a questionaire and one of the questions had to do with "steel in the eye".... to jump to the end of the story, I had to first have my eyes Xrayed to be certain all the steel was indeed out or the MRI magnets would PULL IT OUT.... ouch!
So, good advice, wear eye protection, ALWAYS.
71MKIV
Oh boy have I BTDT. Rust in the eyes is fun too.
I like how the whole world distorts as he weilds his little drill.
splinters spun off by a carbide burr are the worst.
V
vagt6
Tabcon, thanks for the war story. You may have just saved someone's vision! I hope your eye comes back soon!
Eye protection is so easy: just find a pair of goggles or approved eyewear that fits, and WEAR it!
Wear anytime you're under the car;
Hammering;
Sawing;
filing;
At the grinder/polisher;
Anytime stuff is flying around you.
We have a guy at work who was hit in the eye by a stick recently: torn retina, 80% blind for life.
All preventable. :yesnod:
trfourtune
Yup, dremmel and die grinding, frankly, any grinding, is nasty. Also beware of blowing out the block with your compressed air as well-don't use vented goggles with holes unless you close your eyes tight. Don't ask how i know.
Rob
19_again
Thanks Tabcon,
I've got three pairs of goggles and I wear them about 20% of the time, thanks for reminding me to ALWAYS wear them. Hope you're all set soon.
Mike
BobbyD
Been There, Done That too...........Those MRI people are real serious about verifying that there's no metal in your eye. One of the questions asked is if you do any welding too.
Tabcon
Tabcon
Re: Suggestions For Drilling A Hole in your EYEBAL
I went out to the local hardware store yesterday and bought a new pair of the glasses type eye protectors. So much better than those doofus goggles.
The only problem now, is that I need a decent compressor to run my die grinder. Right now I have two small nail gun type compressors hooked together in tandem and the pressure lasts for about a minute at most. I've looked all over at compressors, but I haven't bought anything yet. I only have 110 in my shop (garage) so it limits the size I can get.
A lot of my professional framers and trim guys use the twin tank "RollAir" compressors and swear by them. I need something a little larger and found this one for a little over 700 bucks.
TR4nut
Tab-
Have you looked at putting in a 220 line in the garage? If your breaker box is there it shouldn't be that costly, and it opens the door for a pretty beefy compressor at similar prices to what you are considering.
Randy
trfourtune
Tab,
If you plan on ever getting a 100lb pressure sand blaster, you will need at least 100cfm @ 100psi. That's a big compressor. If you want to run pneumatic body sanders, buffers etc, you will want a big compressor. In my mind, you can never go too big. A die grinder doesn't use much air but a lot of the other tools do. Air tools are the best! The rest are Mickey Mouse IMHO. I have a 5 hp 220, 20 cfm. ALWAYS look at the cfm output. this is what counts! BIG cast iron pumps are the way to go.
good luck.
Rob
ps-remember to drain you air tank often (we have high humidity so lots of water builds in the tank)
rooster
I agree with Rob.
The one you are looking at looks good but you really need at least 60 gallons tank. Most air tools run at around 10 cfm so you need one that'll do about that too. For painting your going to need more, about 20 cfm, if you're going to do a lot.
I'm going to get a 60 gallon 10 cfm one that'll run my tools fine and be ok for occasional painting. It's not optimum, but fits my budget, and the space that I have in my garage.
Cheers
bgbassplyr
Tab, Check Harbor Freight, Pep Boys, Sears. All have large, high output compressors with large tanks for that money. The size you pictured is available around here for less than $400.
Check for Sears outlet store, usually in league with their parts store, and they will have repos, returns, warranty repairs for less money w/warranty.
Jim
Tabcon
Tabcon
I bought a DeWalt electric die grinder yesterday and it works very well. I would still like some air though, and you guy's are right, I need a larger size compressor. The problem is getting 220 to the shop. It can be done, but we'd have to hang about 80' of conduit under my house, run through my wife's flower beds and then tunnel under a couple of sidewalks to get to the garage. I did this last year with a 1.5" natural gas line for a pool heater and it was a major mess. I was thinking it would be cheaper to just stick the compressor in our bedroom and run a an air line across the back yard to the garage. I told my wife I could paint it to match the curtains if she wanted.
DNK
Gee, I don't see why she'd have a problem with that :jester:
I Suggestions for drilling a hole in a grade 8 bolt? Triumph 24
I Bugeye valve rebuild suggestions Spridgets 8
D Shop lighting suggestions. Restoration & Tools 8
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
catfood Looking for suggestions - ignition issue Austin Healey 6
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
Bob_Spidell Rebuild Performance Suggestions Sought Austin Healey 8
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
RAC68 Gear Reduction Starter Infor and Suggestions Requested Austin Healey 11
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
I General TR Mold clean up suggestions Triumph 4
Got_All_4 TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts Triumph 4
M suggestions on vendor Rear brake rebuild Spridgets 15
DerekJ Healey Blue Paint - suggestions Austin Healey 23
J General TR D Type overdrive not working need suggestions Triumph 5
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
I TR6 suggestions for brake LED bulbs Triumph 13
dcoplan Tires rubbing on frame - suggestions? Spridgets 2
I TR6 Muffler suggestions? Triumph 6
HealeyDave Car transport company suggestions needed - winter/midwest/USA Austin Healey 2
M Overdrive parts source suggestions Austin Healey 4
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
S TR6 Suggestions: cylinder head won't release from block Triumph 10
Zimmycobra Trans problem. Looking for suggestions. Triumph 10
S Any suggestions on where to start? MG 7
D TR2/3/3A Suggestions needed for TR3 pricing Triumph 10
M TR4/4A 67 TR4A hasn't run for 10 yrs+... suggestions? Triumph 11
TRMark Brake pad suggestions Triumph 16
I Suggestions for bugeye headlights Spridgets 21
M suggestions for brake system Spridgets 9
RAC68 Paint & Design Suggestions Triumph 4
Andrew Mace lacquer primer removal suggestions Triumph 4
I LED tail light suggestions? Spridgets 22
G TR6 Radio suggestions for fitting to TR6 Triumph 3
hondo402000 suggestions on Ignition coils Triumph 22
I Suggestions for tach gear rebuild? Spridgets 8
J rear brake rubbing, need suggestions Triumph 12
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
I Adhesive suggestions? Spridgets 4
I Wax, rubbing compound suggestions Spridgets 10
AngliaGT Subaru Wagon Suggestions? Other Cars 8
I Suggestions for new Bugeye soft top? Spridgets 3
TomMull carburetors not pretty, cleaning suggestions neede Triumph 13
RAC68 Suggestions – LED Project Austin Healey 24
