healeyboz
still working out the "bugs"
Got the oil leak fixed from the front of the motor. It took getting a new timing cover, straightening the front motor plate, new seals (again) and a speed sleeve. A bit of over kill perhaps, however, NO MORE LEAKING FROM WHERE IT IS NOT SUPPOSED TO!!!!
Now to the fuel issue. Has anyone had any problems with the new fuel tank from ebay?
I know that I have a richness issue. Still trying to set the carbs. Replaced fuel pump (elec.) fresh line from the tank to the pump. I just don't know???
It is as if the car is starving for fuel. It happens intermittently. No real rhyme or reason. I can set the regulator up to 3 lbs and it fixes the problem for a bit. I have still had the problem at 3 lbs. Thoughts???? If I run 3 1/2 lbs I get fuel in the oil.
