General TR Still Losing Oil
KVH
Now that I have my car running great, I'm focused on the loss of oil. It's not from a leak. What shows up on the floor seems trivial. Teaspoons. But I'm losing 1/2 quart a week, driving maybe 120 miles. I'm still running a bit rich, and, to me and at least some onlookers, the exhaust is black, not blue or gray. My plugs have been sooty when too rich, but now they're clean and gray/brown.
I rebuilt my engine 9 months or so ago.
Can it be that I screwed up the rings? Wouldn't my plugs be wet or oily if my rings were allowing oil past the block?
Any more ideas about my oil loss?
Gliderman8
I had a similar situation with my TR6. It drove me crazy trying to find out the source of the leak. It turned out to be coming from the dipstick tube! The crankcase was not properly vented. Once Ken (pool boy) helped me sort things out the leak stopped. May not be your case but I'm putting it out there as a possibility.
TomMull
I think Elliot's on the right track. I think a plugged system or one injecting too much oil into the intake could account for all your issues. Tom
Geo Hahn
Sometimes when there is an oil loss but not much of a puddle on the garage floor it is because the oil is only lost while the engine is running well above idle - suggesting a leak that is from a source under pressure.
Do you have a spin-on adaptor? I ask that as they can be a troublesome seal (the one between the adaptor & filter head) that can cause a running leak.
In any case, I'd be examining the engine, not the floor, to pinpoint the leak (if there is one).
Gliderman8
I would also check the valve cover gasket. I switched to a silicon gasket and that was a big improvement.
Rut
I know these are different engines, but I had a similar issue with an MGB engine that I rebuilt and it turns out that the modification I did to the tappet cover caused the problem. The MGB uses 2 tappet covers with 1 vented to the carbs via a rubber hose that splits just before connecting to the SUs. I made an aluminum plate to replace the forever leaky tappet covers and in my infinite wisdom vented both the front and rear individually to each carb without the 'steel wool' to slow the oil vapors so they could condensate and run back into the crankcase. My modification allows for really good negative crankcase pressure, but it consumes oil faster than normal while keeping the rear seal leak free. I haven't decided how or if I'm going to fix the issue, but any increased flow from the crankcase to the carbs or manifold via a PVC valve can potentially increase oil consumption. I don't know if this will apply to the TR engine, but it's so similar to my issue I thought I would bring it up.
Rut
Nelson Warranty still good Spridgets 3
B Does anyone still make or sell a quality condenser? Austin Healey 14
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
sparkydave Odd discovery, but still ran OK Spridgets 1
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
K TR2/3/3A What is the name of this bracket and is it still avaiable? Triumph 4
RAC68 Directionals, Still a Pain Austin Healey 25
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
steveg Steering rebuild followup - still issues Austin Healey 29
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
K For Sale TR3 grille....not perfect but still useable. Triumph Classifieds 2
C elusive amswersHi Mine is a 66 BJ8. I have 2 questions that up till now I still canno Austin Healey 2
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
GTP1960 General Tech Still in business? Triumph 3
KVH General Tech Still on the Body Work Triumph 6
Rob Glasgow Fender Beads still in wrapper Austin Healey 5
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
CZ_Dave MGB I'm Still Around, just busy livin life on lifes terms MG 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
BJ8Healeys The scammers are still at it Austin Healey 3
I Quantum Mechanics Ltd still in business? Spridgets 7
CZ_Dave MGB I'm still around MG 2
J TR4/4A Cam Timing with Head Still On HELP! Triumph 8
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
M Backfiring through carbs still Austin Healey 17
wangdango This BN2 still around? Austin Healey 6
wkilleffer MGB Anyone still use HIF SU carbs? MG 12
R And Still Cooler in Florida Austin Healey 3
mgedit TR2/3/3A Still Overheating ... Triumph 22
Kleykamp TR2/3/3A Still fighting turn signal issues. Triumph 1
bigbadbluetr6 TR6 TR-6 still not running right Triumph 31
G MGB STILL working on clutch slave MG 37
B TR2/3/3A After a beating, the tunnel still lives Triumph 6
rjc157 I Donald were still alive Austin Healey 15
RAC68 Still being Surprised Austin Healey 7
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
Lukens TR2/3/3A Let's see if I'm still having the 'Britishcar forum not responding" problem Triumph 3
P T-Series Does my Mark II TD still exist? MG 3
mrv8q They're still out there..... Austin Healey 26
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
KVH TR4/4A TR4A--still won't start Triumph 16
G MGB Still working on front suspesion MG 9
Jim_Gruber Spring is getting closer - What Spridget Winter projects do you still need to finish Spridgets 13
B Hello Gents....long time gone...but Im still at it..lol Triumph 1
dougie Still Time for Christmas Austin Healey 2
jlaird Still here Spridgets 5
X Royal Enfield Bullet, still in production British Motorbikes 4
Frank C. How many Healeys are still on the road? Austin Healey 10
WedgeWorks Still Great Stuff Out There! Triumph 4
