Steering Idler problem
Cutlass
After complete disassembly, cleaning, new oil seal, new gasket and reassembly, my 66 BJ8 steering idler binds. The shaft seats nicely, and rotates freely until I put the cover on. Anything more than finger tight on the bolts results in the cover binding on the top of the shaft. I tried each position possible for the cover, and added an additional, home-made, thicker gasket, to no avail. There was no shim at disassembly, and none shown in the service parts manual. The top of the shaft sits proud of the idler body just enough to touch the cover. Any ideas? Thanks.
C
Cutlass
Well, as usual, I should have researched this forum first. Looks like the answer is the obvious, stacking gaskets to adjust end float.
Dave Russell
Yoda - R.I.P
I don't know about the BJ8, but earlier cars used selective shims/gaskets to set the end play to near zero but not binding. You may be on the right track but still need more gasket thickness.
C
Cutlass
Shims would be nice, but I haven't seen them advertised or mentioned as available. I do note that in the Moss catalog, the number of gaskets required is "A/R" which leads me to beleive that the gaskets were used as shims.
John Loftus
Cutlass,
I cut several gaskets of various thickness to get the "zero" end float the workshop manual calls for. I've heard the original gaskets were layered .. you would continue to peel off layers until the fit was just right. Nice trick, eh? With any method, it's good to use Hylomar on all the gasket surfaces.
Cheers,
John
Dave Russell
Yoda - R.I.P
Make sure that the gaskets/shims follow the outer contour of the housing & do not cut across the center bearing area of the idler top. The lid itself should be the bearing surface for the top of the idler shaft. Not the gaskets. If the gasket is between the idler top & the lid, it will quickly wear out & increase the clearance.
cutlass, believe it or not when i rebuilt mine i needed such distance i used a piece i cut out from a "dell" mouse pad, been just over a year and works just fine. /ubbthreads/images/graemlins/yesnod.gif
C
Cutlass
The funny thing is that there was only one seemingly thin gasket when I took it apart. And then it worked fine. I'll start with five of them now and work my way down.
6 Problem after installing new steering idler Austin Healey 15
6 Problem Removing Steering Idler BJ8 Austin Healey 9
6 Idler steering Assembly Problem [BJ8] Austin Healey 7
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
T TR2/3/3A Question on steering idler unit Triumph 2
Martinld123 Steering Idler Noise Austin Healey 21
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Lutz Kramer Steering box and idler bush Austin Healey 4
G Steering idler arm removal Austin Healey 33
RickPA Need help installing steering idler oil seal Austin Healey 6
RickPA Clunky steering idler Austin Healey 8
R BJ7 Steering Gear and Idler Rock shaft Austin Healey 4
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
pkmh BJ8 Idler Gear [Steering] Austin Healey 34
S Austin Healey New Steering Idler Assembly Austin Healey 2
J TR2/3/3A How to fill TR3 steering idler? Triumph 10
6 How do you remove steering idler on BJ8? Austin Healey 0
F Steering Idler Austin Healey 14
M Steering idler bushing direction Austin Healey 3
A How do I convince steering arm to come off idler? Austin Healey 10
N Steering Idler Box Austin Healey 3
nevets steering box and idler removal Austin Healey 14
C steering idler Austin Healey 5
S BJ8 Steering Idler Assembly Austin Healey 3
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
