RestoreThemAll
I'm working on evaluating the steering idler and gear box. Following the advice from older BCF posts I disassembled both units. The inside of the box was coated with rust and old gear oil. No surprise, though the rust didn't make me happy.
The races look good, as do the bearings. The column cam and peg seem to be in good condition. I didn't expect the peg to be seated in a roller pin bearing. The pins look fine also. I removed and cleaned all of the above. I took pics of all. Correct me if I'm wrong but I'll reinstall those parts given no damage seems to be present.
Rocker shaft pitting is my first question. Note that the pic is taken through a maginfier. Can the shaft be cleaned up? How much metal can be taken away? Maybe a better question is what is the INSIDE Diameter of the new bushings before they are reamed to fit? Is the fix to clean it up manually, or take it to a machine shop? If I clean up the shaft myself would I just use emery cloth?
My second question is about the very deep pitting in the inside wall of the gear box. There is plenty of metal there but the one pit is real deep. Should I be concerned?
The last question is about the idler. It fits tight with no play at all. Feels fairly smooth. That said there is some scoring on the shaft and the bushings. Should I be concerned?
