Starter Pull
TulsaFred
Is it possible to disassemble and clean the inside of the Bugeye starter pull ("solenoid").
Mine is making poor intermittent contact when I pull it.
I think there is dirt and/or corrosion in there...
Gerard
That's one I think you'd be hard pressed to reassemble. As I recall, it has a rolled edge all the way around. Given how hard it is to bend that metal back and have the assembly really snug, which it need to be with that much current running through it, I think you'd have to be really lucky for it to still be viable. You could always chance it if you're ready to accept you have a good chance you'll have to buy a new one.
TulsaFred
TulsaFred
Are the repros any good? Or should I look for an original?
I may try to take it off and hit it good with WD-40
Sarastro
I've taken one apart to try to fix it, but it quickly became obvious that it didn't make much sense. The contacts were very worn and some of the small internal pieces couldn't be reused. I think a new one was about $15, so it's a cheap replacement.
TulsaFred
TulsaFred
I suppose if the WD40 doesn't perform magic on it, then I'll have to order a repro. I prefer rehabbing the original parts if possible.
JPSmit
sorry to state the obvious but have you cleaned contacts/ checked grounds?
TulsaFred
TulsaFred
Yep, checked and cleaned all accessible contacts and grounds. The issue seems to be the contacts internal to the pull starter/solenoid (what is this thing actually called?).
Jim_Gruber
Fred,
NOS Locators has the solenoid you are looking for on E-Bay at $19.95. NFI. Time is money.
Rut
Jim,
Yep, time is money, but time in the shop is priceless!
Rut
C MGA Change a pull starter to a push button system MG 6
Rut Bugeye pull starter Spridgets 10
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
bugedd Starter pull Spridgets 9
Jim_Gruber Looking for BE Pull Starter Switch Spridgets 18
Mychael Location for pull starter solenoid. Spridgets 11
bugedd Original Starter Pull Wanted Spridgets 4
jvandyke pull starter set up Spridgets 23
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 5
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
