Starter pull
bugedd
Can someone suggest a source for a correct starter pull cable? Mine came apart today, tried to fix it but it came apart again. I found some in Australia on ebay, but not really interested in waiting 2 weeks.
Thanks
bugedd
bugedd
Ya, but how does it look. AH Spares seems to have a nice original style one, anyone have experience with that?
smaceng
I see so many BEs with the wrong starter and choke knobs. Either the shape is wrong, or the letters are wrong. An original one can be brought back to life....refinish and paint in the letter.
bugedd
bugedd
I tried that, but the cable pulled out. I attempted to crimp in another cable, a derailleur bike cable, but it pulled out. I talked to a master welder I know, he said any silver or brass he could flow into it would destroy the knob :(
nomad
Ed, If you use a heat sink and don't spend much time heating you won't destroy the knob. I use a couple of chunk's of lead clamped around the shaft then a quick quench with a can of water as soon as the job is done. heat must be with a torch to get it hot enough for solder quick and you want to use plain old plumbers solder since it doesn't need to get as hot as silver or brass. If you were hiring it done you need to find someone willing to take the time.
Kurt.
markberry
I bought one from AH Spares. It was a perfect copy of the original.
bugedd
bugedd
I ended up using a derailleur bike cable, butane torch, solder, and it worked! Nice to keep the original.
nomad
Good on ya Ed!!
[founding member of the ' we cheeep' club!]
Kurt.
C MGA Change a pull starter to a push button system MG 6
Rut Bugeye pull starter Spridgets 10
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
TulsaFred Starter Pull Spridgets 10
Jim_Gruber Looking for BE Pull Starter Switch Spridgets 18
Mychael Location for pull starter solenoid. Spridgets 11
bugedd Original Starter Pull Wanted Spridgets 4
jvandyke pull starter set up Spridgets 23
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 5
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
