TR2/3/3A Speedometer Routing
Redoakboo
I am in the late stages on the complete restoration of my 54 TR-2 Long Door. I am getting ready to order the tach and speedometer cables. The tach routing is pretty easy. Roadster factory says the speedometer cable in 93" long. I have a overdrive transmission and know where each end goes. It's the routing that I can't find any pic's or schematics on.
If you have anything that would help me route this "Snake" please let me know.
Dick
6TTR3A
Here's the engine bay end on late TR3. I believe the cable shield was black on a TR2 My engine bay2019-L.jpg
R
Redoakboo
The cable is the grey cable running along in front of the battery and then through the hole in the firewall? I assume it's routed from the transmission with clips up the inner fender?
Dick
CJD
It's all here, starting post #52. I know the photos are dark, but all the speedo cable routing and clips are eventually shown in this one post. If you have any questions, feel free to ask...
https://www.britishcarforum.com/bcf/showthread.php?108693-Recipe-for-a-TR2/page2
The gist is...out from tranny to inside C member of the frame. Forward to the right side of the tunnel and up with a clip inside the heater fitting. 2 clips along front of battery box and turn into a through grommet to the interior. Then forward to the gage.
R
Redoakboo
John,
All I saw on the pic's was front brake stuff??
Dick
CJD
Post #52, about mid way through the post. There is a lot of info in post #52. If you skim down every clip and section is eventually shown. Like i said, I apologize for the dark Green with no contrast! I can brighten any pics you need better detail.
Unfortunately all these pics were on photobucket, which won't let me re-post them. I will try to reassemble the cable photos when I get back to my hard drive so I can re-post via Imgur.
R
Redoakboo
Thanks John, I think I have an idea the route takes. I can now see why it is so long.
Dick
carpecursusII
Ill throw a different opinion out there. Here are two Tr2s, no OD, that have a different routing. The red car is TS 5265 found in very original condition and the white car is TS3285 also in original condition.
Graham H
Different route altogether for non overdrive, if you look at my photo you can see the brake pipe going forward and through a large grommet in the chassis , the speedo cable goes through the same grommet then up the firewall across in front of the battery box and through a grommet behind the speedo.
Graham
CJD
OK...as promised. I am using my pre-build photos, so you have more definition. But here goes the entire run...
So here we start with the end of the cable where it plugs into the OD tail section. It comes straight out, under the floor where the handbrake boot is located and curves forward.
Now you see it passing through the section of frame with the brake line (and grommet as everyone mentioned. This allows it to come back inboard towards the starter.
Here it is along the starter. Time to add the body to the pictures....
Here the cable is held with a brass clip to the firewall, very close to the tunnel. The screw is the same one that holds the RHD steering column blanking plate. It is now going to turn across the firewall to the driver's side.
Another brass clip at battery center brings it over to the driver's side.
And to wrap up the run, it turns and enters the pax cabin through a grommet right in front of the speedo.
Hopefully this will clear it up!
CJD
She is a very lucky car. If it were any other owner, or any other time in my life she would have gone to the crusher. All the pain of restoration has faded and she pays it back by making me smile every time I drive her. I've owned a lot of cars, but she gets more waves and honks than all the others combined. The frustration is worth it in the end!
M TR4/4A Speedometer Cable Routing Triumph 7
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
C routing of speedometer cable on BN6? Austin Healey 11
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
J TR4/4A TR4 Speedometer cable routing Triumph 0
TimK Speedometer Cable Routing - BN7 Austin Healey 2
HEALEYJAG 100 speedometer cable routing Austin Healey 5
6 Speedometer Cable Routing Austin Healey 2
B Speedometer Cable Routing Question Austin Healey 3
G Routing the speedometer cable Austin Healey 4
M TR2/3/3A HVDA Speedometer Drive Triumph 10
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
DocDup1 MGB SpeedBox Speedometer Drive MG 0
R TR2/3/3A Speedometer Reset Triumph 26
BritBite Speedometer Right Angle Drive Austin Healey 5
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
M TR6 Speedometer Triumph 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
RJS TR4/4A Speedometer and Angle Drive Triumph 6
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A Speedometer Works Removal Triumph 10
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S Speedometer Angle Drive Austin Healey 2
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
F How does overdrive Annulus effect speedometer Austin Healey 10
2 TR2/3/3A Can't get zero on speedometer 60K tr3A Triumph 6
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
Michael Oritt Speedometer drive issue Austin Healey 4
