rocker oil pressure or not enough?
Jerry
I was helping a friend get a 1971 MGB running. They bought the car a while ago but have not tried to drive it yet because of a warning by one of our club members that the valve train sounded loud. The engine was rebuilt according to the guy that sold it. I pulled off the valve cover and can barely see the oil coming out of the rockers. IE: the back pedestal has oil slowing dripping out of the nut on top. Each of the others has much less oil and the push rods for the front pedestal had no oil on them. Oil pressure according to the gauge is 50lbs at idle. Sounds high to me but I usually work on Triumphs and Austin Healeys. I know the oil feed is from the rear pedestal but is there any way they turned the rockers bushes so the oil hole is pluged?
Any other ideas? (plenty of oil in the car)
I can tell that someone spent a lot of money on this car. Lots of little extras everywhere and the engine is pristine.
Thanks
Jerry
PAUL161
50 lbs of oil pressure at idle is good! The 1800 engines were never at the top of the list for rocker arm oil pressure. Just make sure the oil galleys are clear, in the block, rocker shaft and bushings. Sometimes engines are "rebuilt"???, and little attention is given to the oil galleys which can get crudded up over a period of time, especially if the oil wasn't changed at the proper intervals and the detergents have deteriorated to non existence.. PJ
CZ_Dave
Throw some Marvel Mystery Oil in with the
Just a quart will do, run it for a while.
Then do a oil change, maybe that will clean
out the oil galley's, stuff works,
always keep some around for old car startups.
rlich8
There will not be a puddle of oil in there, should just be more so of a light to moderate coating. As long as the rocker shaft is lubricated and there's a little bit in between the rocker arm and the valve, you should be good.
It's not like a Jag engine where the cams are literally bathing in oil.
J
Jerry
That makes me more comfortable. I think we will add some lower weight oil like Marvel to make sure all the oil holes are open. This has not been run in almost a year now. It did start right up and ran for about 5 min before we had to shut it down due to the switch melting.
thanks
Jerry
Deleted member 8987
I'd pull the rocker shaft assembly, crank it and see what comes out the oil port, and I'd use either a bunch of pipe cleaners to probe (and clean) or a small wire brush like is used for cleaning valve guides.
Then I'd slide all the rockers over, check the ports and check for adverse wear.
But, then, that's just what I'd do.
M Healey 3000 a large of oil fumes fro rocker cover Austin Healey 14
M Rocker Arm without Oil Bleed Hole Austin Healey 4
rlich8 "Oil Screw" on Rocker Shaft Triumph 6
C Rover 3.5, Minimal oil to rocker shafts. Triumph 17
D Oil Spraying from Rocker Shaft - BJ 8 Austin Healey 10
eschneider external rocker oil feed line Triumph 13
TheAssociate Water In Oil - Normal?/Rocker Oiler Triumph 9
S GT6 GT6/TR6 rocker shaft oil problems. Triumph 5
kch Rocker pedestal - oil feed threads ? Austin Healey 13
Y TR6 TR6 - Secondary oil feed to rocker shaft Triumph 12
C Rocker oil feed lines Triumph 2
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
M Rocker feed kit for 1500 from Victoria British Spridgets 0
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
Jim_Stevens For Sale New Rocker panels TR3A Triumph Classifieds 1
P TR6 Rocker panel hole Triumph 16
D MGB MGB rocker shaft shims MG 1
Lukens Outer rocker showing "rust" Restoration & Tools 11
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
D rocker arm assembly Austin Healey 14
Rut Replacing rocker assembly Spridgets 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
P Rocker Cover Vent Spridgets 22
matmire rocker arm stress cracks? advice please. Spridgets 2
red57 Outer Sill/Rocker fit problem Austin Healey 11
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A rocker covers again Triumph 13
M TR2/3/3A Rocker cover question Triumph 11
S MGB-GT Wanted: REMCO MG Rocker/Valve Cover MG 0
S TR2/3/3A rocker cover panels for the pre60K tr3 Triumph 1
